Need Help Decoding 1965 F-600
Old Jan 25, 2013 | 09:16 PM
towmaster's Avatar
towmaster
Just acquired a really nice 1965 F-600 dump truck. Truck has only 24,000 original miles, and very minimal rust. The only thing wrong with it is that the transmission pops out of reverse gear. I have all the info off of the door VIN tag. Please help me find out everything there is to know from this tag.
VIN: F60AE71277
WB: 132
Model: F602
Body: 481
Trans: N
Axle: 64C
Max GVW: 20000
Cert. Net HP: 160
RPM: 3800
DSO: 323594
Old Jan 26, 2013 | 12:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The only thing wrong with it, is that the transmission pops out of reverse gear.
VIN: F60AE71277 / WB: 132 / Color: Blank / Model: F602 / Body: 481 / Trans: N / Axle: 64C / Max GVW: 20000 / Cert. Net HP: 160 / RPM: 3800 / DSO: 323594
24,000 original miles is unrealistic on a 48 year old truck, especially one that was used commercially.
Do not believe the mileage, as the odometer reads to 99,999.9 then returns to ZERO! So, it could have 124,000, 224,000 or who knows how many miles.
F60 = F600 (gas).
A = 330 2V Medium Duty FT engine.
E = Mahwah NJ Assembly Plant.
71277 = 1965, assembled July 1965.
132" Wheelbase.
Color: Blank.
F602 = F600 (gas), 20,000 lbs. GVWR
481: 4 = Light Beige Crush Vinyl & Light Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
N = New Process 435 4 Speed Manual Transmission.
64C: 64 = Timken model F106 Single Speed Rear Axle / 6.80-1 / 15,000 lbs. Rear Axle Capacity // C = Ford-Rockwell-Timken Front Axle w/6,000 lb. capacity.
20,000 lbs. Gross Vehicle Weight Rating.
160 net HP @ 3,800 RPM
323594:
32 = Cleveland OH Ford District Sales Office, where the original selling dealer ordered the truck from.
3594 = Domestic Special Order number. The truck was ordered special by the original purchaser, not "bought off the lot."
No Color code on the Warranty Plate: The vehicle is painted a non standard color per the original purchasers order, making it a Domestic Special Order.
Old Jan 27, 2013 | 06:29 PM
towmaster's Avatar
towmaster
Thank you for help. As far as the mileage goes, I do not find it unrealistic due to the fact that the truck is nearly 99% rust free, and that it was owned by a college which used it on campus for snow plowing, and landscape work. They said the truck rarely left campus and they purchased the truck in 1982 with a mere 16,000 miles on it back then.
shillinghillf600
Large Truck
Mar 30, 2019 12:16 AM
Jim P.
Large Truck
Dec 1, 2017 09:46 AM
mpokoney
Large Truck
Aug 3, 2015 12:08 PM
stillwater ford
Large Truck
Jul 24, 2015 04:01 PM
coyote1442
Large Truck
May 20, 2015 05:24 AM
