Replacing air filter. Which style to get?
Old 01-25-2013, 03:04 PM
Saxon's Avatar
Saxon
Saxon is offline
The old filter that I am replacing is an element only that is pleated and cone shaped, green color.
Some new filters have the housing and the element built together, with a honeycomb style element.
What are the differences?
Thanks
Old 01-25-2013, 03:49 PM
Bluestroke2004's Avatar
Bluestroke2004
Bluestroke2004 is offline
sounds like you have after market, if I were you I would go back to OEM.
Old 01-25-2013, 03:50 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Absolutely the only way to go on a stock truck
Old 01-25-2013, 07:57 PM
69cj's Avatar
69cj
69cj is offline
And make sure you get the blue lined cellulose filter, not the white.
Old 01-25-2013, 08:30 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
looks like the guys have all Important stuff covered
X-3 on OEM AIr Filter its a Good One
And Typicaly Last 100K with Normal Use
Old 01-25-2013, 09:07 PM
VQT's Avatar
VQT
VQT is offline
Is there a difference? Frame sell the white not blue!
Old 01-26-2013, 09:18 AM
Saxon's Avatar
Saxon
Saxon is offline
Yes what would be the difference between blue and white?
The Napa store in town had a Wix filter but it was white and $84.
Old 01-26-2013, 09:24 AM
Regulator1988's Avatar
Regulator1988
Regulator1988 is offline
The diffrence in color really makes no diffrence. I used to run the wix filter and loved it. The best filter for your truck is the stock set up. Do not to a cheap cold air, if you do make sure it is not oiled. But like the guys have stated a stock air filter is good up too 700hp (I think) and it filters better also
Old 01-26-2013, 09:36 AM
Saxon's Avatar
Saxon
Saxon is offline
The green aftermarket that I am replacing is a 'no-name on it' peice of junk. It has collpapsed in the housing and not sealed off, now the inlet pipe to the turbo is oily and dirty.
Old 01-26-2013, 10:27 AM
Roasted7's Avatar
Roasted7
Roasted7 is offline
The Pro Dry 7 from AFE is excellent. I've had mine for over 50,000 miles now and my turbo compressor wheel is spotless clean.
Old 01-26-2013, 10:32 AM
bismic's Avatar
bismic
bismic is online now
Received 2,509 Likes on 1,744 Posts
That is not correct. The blue media is a water resistant synthetic and will not start to blind off if blowing snow or moisture gets on the filter element.
Old 01-26-2013, 10:33 AM
Regulator1988
Originally Posted by bismic
That is not correct. The blue media is a water resistant synthetic and will not start to blind off if blowing snow or moisture gets on the element.
I stand corrected, i dont get any snow here
Old 01-26-2013, 10:37 AM
bismic's Avatar
bismic
Some folks that did the zoodad mod noted that they got more moisture on the air filters from blowing rain. I have never seen it, but I can see where it can happen. I think (don't know for sure) that Ford's intent was (as you noted) to provide a slightly cheaper option for areas that did not get snow.
Old 01-26-2013, 11:44 AM
69cj's Avatar
69cj
69cj is offline
For as long as these filters last don't cheap out. Get the blue. You can get a Racor, they make them for Ford, cheaper on line at dieselfiltersonline.com.
Old 01-26-2013, 02:56 PM
shawkins89's Avatar
shawkins89
shawkins89 is offline
I thought the OEM filter setup was designed and made by Donaldson and Racor was responsible for the Oil/ Fuel filters and HFCM.
Quick Reply: Replacing air filter. Which style to get?
