Driver's side door lock
Old 01-24-2013, 05:44 PM
nick5446's Avatar
nick5446
nick5446 is offline
Here's the idiot question of the day - how do I lock my driver's side door?
Passenger side has the separate lock under the handle with the little cover, driver side doesn't (nor does it have one in the handle's button like I've seen). Is manipulating the handle "down" from the inside supposed to lock it? Were door locks another thing that was an option back then, that we take for granted now?
I was born about 30 years after my truck was made, so excuse my ignorance.
Old 01-24-2013, 07:42 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Drivers side door-locks were an option. They wanted you to, for your protection, to enter from the curb side, and slide over. Pushing the inside handle down will lock it.
Old 01-24-2013, 08:13 PM
cparks's Avatar
cparks
cparks is offline
My 60 is the same way, but wanting to look how to add a one to it. Otherwise going to put at least power locks on it.
Old 01-24-2013, 08:23 PM
Walston's Avatar
Walston
Walston is offline
The door locks by pushing the handle forward. Slide over and exit the passenger side where you can lock that door with a key. Goes back to all parallel parking. In many towns it was illegal to exit from the driver side.
On the drivers side door, everything is there except the key lock. You can easily add the key lock to the driver side by coping the hole from the passenger side and installing a key lock. I did exactly that on my 60. As was mentioned, the key lock was an option.
Old 01-26-2013, 02:21 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Drivers side door lock cylinder and key:
Standard equipment: 1951/54 Deluxe Cabs, 1955 and later Custom Cabs.
Optional: Standard Cabs thru 1963.
Lil' Marlene
1947 and Older Ford Trucks
07-14-2017 06:19 PM
Ford-ified
24
02-29-2012 12:23 AM
iwanaflattie
16
12-02-2010 07:23 PM
kcb37
07-20-2006 11:29 AM
reamer
40
01-17-2005 05:36 PM
Quick Reply: Driver's side door lock
