47 passenger door lock
Old Jul 13, 2017 | 12:56 AM
Lil' Marlene's Avatar
Lil' Marlene
Good news bad news....figured out that the steering lock also worked my passenger door lock! Got the drivers internal forward lock working with a little pen oil!
Bad news was I got my passenger key lock to turn and lock but now it wont unlock.☹️
Dont want to break the key...was going to ask how to pull the passenger door lock to get it re-keyed...but then what happened to my steering lock(third key I guess.
so my new question...How do I pull my passenger door lock cylinder above the handle?
Old Jul 13, 2017 | 07:58 AM
tacomacream's Avatar
tacomacream
Is the door shut and locked?
Old Jul 13, 2017 | 08:59 AM
Lil' Marlene
Yes but I can still open and close it from the inside through the drivers door...just not sure why I could lock it with the key but now can't unlock it.
Old Jul 13, 2017 | 10:35 AM
Rust Wrangler's Avatar
Rust Wrangler
Lube the lock up well and work the key repeatedly in and out and wiggle it around while trying to unlock it. Most likely one or more pins inside the lock are sticking inside the tumbler. Doing this may allow them to break free so the lock will turn.
Old Jul 13, 2017 | 12:53 PM
tacomacream
Check out the 42 Ford door lock thread below on here.
You should be able to take the lock cylinder out and oil it etc.
Old Jul 13, 2017 | 10:48 PM
Lil' Marlene
thank you I'll give it a shot! 😉
Old Jul 13, 2017 | 10:55 PM
Lil' Marlene
I must be an idiot
i can't find the thread could you cut and paste it for me here (sorry and thank you)
VERY APPRECIATED
Old Jul 14, 2017 | 10:39 AM
Rust Wrangler
Here: https://www.ford-trucks.com/forums/1...1-pick-up.html
Simply remove the retaining screw and pull the entire lock assembly out. Anti seize compound on that screw when reinstalling it is a good idea.
Old Jul 14, 2017 | 05:50 PM
Lil' Marlene
Gotter! Thank you guys are AWSOME!
glad I found this site!
got the key made for it today works the column, the door and fixed the driver side so I'm good to go with security now.😊
Old Jul 14, 2017 | 06:19 PM
Rust Wrangler
Sweet! Glad you got it!
reamer
46
May 21, 2025 11:59 PM
Aus56
Jun 28, 2014 06:35 AM
adamkat22
Dec 13, 2013 06:04 AM
nick5446
Jan 26, 2013 02:21 PM
Ford-ified
24
Feb 29, 2012 12:23 AM
