Differences in 7.3s?
Old Jan 24, 2013 | 06:29 AM
bennett11's Avatar
bennett11
After 400 000km my 2000 F250 is in need of an engine.
I found one with only 81 000km but its out of a 03 Tow truck.
I know theres some changes between the engines. But what information would I need to know to tell if I can put this engine in my truck? Or is it one of those things where it will fit if I change enough stuff?
Sorry for being so vague. Just looking for some info before I go look at this engine to have a better idea on what to look for.
THanks
Old Jan 24, 2013 | 08:46 AM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
I believe it is simply a plug and play item. Just make sure you have all the sensors and the other things you want off of the old engine, if anything.
Old Jan 24, 2013 | 09:31 AM
srteach's Avatar
srteach
2000 to 2003 is no difference. As said by twg1966, plug and play.
You may find that the 2003 engine has add-ons. Get them if they are offered.
Old Jan 24, 2013 | 11:02 AM
Tugly's Avatar
Tugly
There are construction differences that only matter if you try to power up past the mid-400 HP range. Other than that, rock and roll.
Old Jan 24, 2013 | 12:29 PM
bennett11's Avatar
bennett11
Thats great. Since I posted this thismorning I have since pulled my engine. Was gona have it to compare to the other one. But if you fine folks say its the same then I will just go ahead and install it.
Thanks again
Old Jan 24, 2013 | 12:35 PM
twg1966's Avatar
twg1966
Swap it in and button it up. Then fire it up and go driving.
Old Jan 24, 2013 | 06:47 PM
Mark Alligood's Avatar
Mark Alligood
Hey Tugly, can you elaborate on that?
Old Jan 24, 2013 | 07:54 PM
JOHN2001's Avatar
JOHN2001
What he is talking about is the connect rods. PMRs and forged rods. PMRs are only good up to around 450ISH hp the forged rods are good for more HP
Old Jan 24, 2013 | 09:28 PM
Tugly's Avatar
Tugly
Yup. JOHN2001 covered it.
Old Jan 25, 2013 | 03:49 PM
bennett11's Avatar
bennett11
Turns out the engine is out of a 97 rather then an 03. Im spending more time swapping **** from my old engine to the 97 then it took me to remove it.
Old Jan 25, 2013 | 04:36 PM
srteach's Avatar
srteach
Yes, there are some differences between a 97 7.3 and a 00 7.3. I'm not sure of the actual differences between them, though. Still worth it, I think.
Old Jan 25, 2013 | 06:31 PM
Kdr358's Avatar
Kdr358
There is a difference in manual trucks vs auto. Going from auto to auto is no issue but going from manual to auto is difficult because of the dowel pins that align the manual are much longer.
Old Jan 25, 2013 | 06:50 PM
SpringerPop's Avatar
SpringerPop
The fuel pumps between these two engines are also different.
Plug the hole in the early block's valley with a freeze plug and use the frame-rail pump already on your 2003.
For a more comprehensive listing of block changes, see this PDF attachment:
Pop
Old Jan 27, 2013 | 03:26 PM
bennett11's Avatar
bennett11
Pop
I wanted this job done this weekend and I didn't have a plug. So I removed the pump and took the plunger out of the pump and just put the pump back in.
The swap is done. A lot of work but worth it for the most part. I just need a new IPR and Im good to go.
Old Feb 6, 2013 | 11:45 AM
99 350's Avatar
99 350
Was just wondering if you swapped the whole front cover and oil pan. Ive heard they are different also. Im looking to do this same swap on mine. Any info on all you did would be greatly appreciated. Did you have to raise the cab at all? Thanks
carguy94
Oct 26, 2017 10:58 AM
52willys
Jun 16, 2014 08:36 AM
powersj
Oct 6, 2010 03:27 PM
Tony1790
Nov 17, 2004 05:29 AM
