High Idle - Not Regeneration
Anyone having a higher then normal idle on the 08's ? It is not regenerating and it has been doing it for a couple of weeks. Makes weird noise in engine compartment when shutting off also. Diesel tech at dealership says they are considering it normal, he pulled two other 08's off the lot and said they did the same. I asked " What about the shut off noise ?" He mentioned it could be the fan. Wondering if anybody else is having the same at all ? Truck has about 14,000 miles on it.
Try leaving it in park for a few minutes while it is in park to see if it goes into an active Regen. I noticed mine once spiking from about 650 RPM's to about 800 for a few days and I didn't know what was going on until I left in in park while running and then it went into Regen. Not sure if what RPM's you are experiencing but that is what happened to me although it sounds like yours has been happening for a long period of time.
How do you tell if its in regen or not?
As Sanddemon said, the "flutter" is very typical on shut down during regen, even if you depress the brake and lower the RPMs, there is still the telltale flutter sound. High idle in cooler temps is a normal op as well. Don't know where you live, but I have experienced high idle warm up in the 40s here.
Thanks guys, Im in florida. I can tell when its in regen, turbo gage goes crazy, you can hear the coolers making weird high pitched sounds like the turbo's are winding out and hit the restet button for the fuel and you will see that you are getting 8.9 mpg's. I stomped on it today and it didnt idle high when i came to a light, would anyone of you guys think that maybe one of my turbo's is acting funny ?
<TABLE border=0><TBODY><TR><TD width=230>FORD:
</TD><TD>2008 F-Super Duty</TD></TR></TBODY></TABLE>
ISSUE:
2008 F-Super Duty vehicles equipped with the 6.4L diesel engine are equipped with an oxidation catalytic converter (OC) and diesel particulate filter (DPF). The function and operation of these parts may cause some customers to perceive an issue with their vehicle.
ACTION:
Review the Operating Characteristics with the customer.
OPERATING CHARACTERISTICS
Diesel particulates in the exhaust are trapped by the DPF. Regeneration is the process by which exhaust temperatures are increased so the particulates are combusted.
The frequency and length of regeneration will fluctuate as both are determined by the drive cycle. For most drive conditions, regeneration frequency will vary from 100 - 600 miles (161 - 804 Km) between occurrence and last from 10 to 40 minutes. The first regeneration does not require 100 miles (161 Km) and may occur at any time. The length of regeneration is usually reduced if a constant speed above 30 MPH (48 Km/h) is maintained.
The following is a list of normal operation while the vehicle is in regeneration, and do not require repair. If you are not sure if the vehicle is in regeneration, IDS can be used to monitor the Diesel Particulate Filter (DPF) PID.
- Engine idle speed can be 1100 to 1200 RPM in park/neutral with foot off brake.
- High idle speed drops to within 50 RPM of normal idle when the brake pedal is touched, PRNDL is actuated, or clutch is actuated.
- White smoke in cold ambients is normal and the amount will be increased during regeneration.
- Powertrain power is limited to 325 horsepower (HP).
- Engine responsiveness may be slightly different than normal operation.
- During initiation of regeneration, exhaust smell may be noticed - especially on new vehicles.
- Powertrain sound will be different including air induction noise (including flutter on deceleration or engine shut down), exhaust noise, and changes in engine radiated noise.
- During regeneration, exhaust temperatures are elevated.
Thanks Guys, It stopped High Idle for about 2 days, and it is now back and doing it again. Not in regen, press break does not drop RPM's one bit. Still making the "flutter" sound when shutting off also. It is Idleing just above 500 RPM, and it is usually below the 500 mark. There isnt more then one type of regen is there?. Sanddemon thank you for the article anyways, Ford has given me a print out of that also. Anything else you guys could think of that would cause this ? I'm new to diesels.
This really does sound like a regen to me. I only drive my truck about 2 or 3 days a week, since diesel hit $4+, probably not more than 20 miles at a time in stop & go city traffic. Was just about ready to take it to the dealership. Decided, on the way to the grocery store, to drive it a little longer at highway speed. Within 30 miles at 65mph the boost gauge stopped going up & down & the high idle was gone at stops ......... just needed to complete a regen. If it never completes a regen, it will just start over again, it needs to be run. Just my 2 cents of my own experience.
Strokin82
1999 to 2016 Super Duty
17
06-06-2020 12:00 AM
wharrell
6.7L Power Stroke Diesel
77
10-30-2016 12:01 AM
wharrell
15
04-24-2015 05:14 PM
