Transfer Case Removal Question
Old Jan 23, 2013 | 09:44 PM
TX76F250's Avatar
TX76F250
'99 Expy, 5.8L, AWD.
I'm swapping out my transfer case. I can't find my Service Manual CD.
Do I have to remove the transmission cross-member and mount to get at the bolts that hold the xfer case to the trans? It seems that if I did, it would give me good access. If it's not necessary, is there a tip or trick to getting the bolts out?
The Old Lady is all over me to get this done so any help is greatly appreciated!!
TIA!
Old Jan 24, 2013 | 11:53 AM
alloro's Avatar
alloro
The time it takes to remove the crossmember is small compared to time you will save by not having to work around it. For the bolts it's either air tools or a large breaker bar.
Old Jan 24, 2013 | 07:32 PM
TX76F250's Avatar
TX76F250
Thanks AP!! I was hoping you were around!
Old Jan 24, 2013 | 07:49 PM
TX76F250's Avatar
TX76F250
Should I support the trans with a jackstand or something or can it just hang?
Old Jan 25, 2013 | 02:34 AM
alloro's Avatar
alloro
Definitely support it, otherwise you can tear the rubber in the two motor mounts, or pull on wires and vacuum lines until they break as the tranny/engine assembly sags down. Try not to support it by the pan. But if you have to, place a piece of 2x4 (or similar) between the pan and the jackstand to help distribute the weight across the entire pan.
Old Jan 27, 2013 | 11:17 PM
TX76F250's Avatar
TX76F250
AP....thanks for your guidance through this project. A buddy stopped by right when I was ready to remove the old xfer case and he helped put the "new to me" one in. After that it was just a matter of putting everything back together.
Test drove it and everything works as it should. No "bound up" front wheels in AWD. I'm thinking about doing the "brown wire mod" as well.
Thanks again!!
Old Jan 28, 2013 | 10:51 AM
alloro's Avatar
alloro
Nothing beats a second pair of hands at a time like that.
Old Jan 28, 2013 | 09:46 PM
TX76F250's Avatar
TX76F250
I hate to say it, especially after the time, blood, sweat, and effort but the original issue is back.
After doing the xfer case swap I test drove it (through about 4" of fresh powder) with no issues noted. (last night)
Today I notice "clunks" in the front driveline while in AWD, usually after a turn. Going in a straight line is pretty normal....after the clunk when you straighten out.
I pulled fuse 104 under the hood and the binding got a bit better but is still there as noted above, during and after a turn.
Having swapped the xfer case and pulling the fuse, wouldn't the only thing left be the front hubs locked engaged?
Any help is greatly appreciated.....this was so disappointing!!!
Old Jan 29, 2013 | 02:26 PM
pdqford's Avatar
pdqford
Front hubs are always engaged (as in splined to the front axles).
Does the 1999 Expy have a 2WD position on the selector switch?
Old Jan 29, 2013 | 03:18 PM
alloro's Avatar
alloro
No, the 97 and 98 had it, but the 2H was removed for the 99 model year.
Old Jan 29, 2013 | 04:26 PM
pdqford's Avatar
pdqford
Okie-dokie. (I have trouble remembering when the 2H went away.)
So, TX76F250, any warning lights on the intrument panel?
And did you check fuses 6, 8, 15, 20, and 23 in the CBJ (that would be the Central Jucntion Box under the dash)?
Old Jan 29, 2013 | 05:47 PM
TX76F250's Avatar
TX76F250
All those fuses check out fine. None were open.
No warning lights on the dash. According to the dash, everything's cool.
Old Jan 30, 2013 | 11:45 AM
pdqford's Avatar
pdqford
Take the front driveshaft out and see if the clunking (?) goes away.
Old Feb 1, 2013 | 02:53 PM
TX76F250's Avatar
TX76F250
dropped the front driveline.
No binding.
Now what?
Old Feb 1, 2013 | 03:48 PM
pdqford's Avatar
pdqford
No binding.
Must be the front hubs, axle halves, and front diff are not the issue.
So I'm thinking the issue is within the transfer case or transfer case shift motor. I'd put the front driveshaft back in and drive it in both A4WD and 4H to see if there is any difference between A4WD and 4H.
Also, are there any codes in the PCM? For example, both the PCM and the GEM receive the TPS signal. The GEM uses the TPS signal to anticipate rear wheel slippage when in A4WD. If the TPS signal has any drop out the GEM might be activating the TOD function when it shouldn't.
All four tires are the same size?
just another truck
19
Apr 30, 2014 07:00 AM
Brad2005F350
Dec 29, 2012 05:23 PM
Chickenguts
Jan 25, 2009 02:14 PM
cooter0124
Jan 8, 2009 08:10 PM
tmbr
Sep 16, 2002 11:07 AM
