2006 Climate Control issue
Old Jan 23, 2013 | 04:24 PM
wildwest2's Avatar
wildwest2
2006 F350 4wd PS Diesel Auto with climate control. Climate module lights up and seems to work fine. I can hear "air" change diections behind the dash when I change temperature. The compressor kicks in and out. No matter the settings on the module, air only comes out the defrosters. When I set the temperatue control to call for heat, I get hot air. When it calls for cooling, I can hear things change behind the dash (such as vent doors), but the temperature of the air is nuetral to warm and still, no matter what vents I have chosen, air only comes out the defroster. The problem started last week with the onset of several days of below zero weather. The weather has improved greatly, but the problem hasn't gone away. Any thoughts on steps to diagnose?
Old Jan 23, 2013 | 04:53 PM
dannyboy950's Avatar
dannyboy950
check your vacum lines for leaks and the vac resivoir. Check your coolant shut off valve the grey hose hasen't coke off. Canister on passenger side valve cover in-line with one of the heater hoses. Low vac heater defaults to defrost.
Old Jan 23, 2013 | 05:34 PM
wildwest2's Avatar
wildwest2
Problem solved
Thanks Dan. After further investigation, I realized the vacuum pump was running all the time. I was starting to believe it was the vacuum pump itself, but when I went searching for proof...as usual, my first guess was wrong. I started disconnecting vacuum lines and plugging them. As it turns out, I believe the solenoid that controls the front hubs leaks when idle (not in 4wd). When I pulled the vacuum connector at the solenoid which comes from the cannister and plugged it, the tank immediately pulled a vacuum, the vacuum pump went idle (working properly on demand) and all my climate controls came back and are workig properly. Unless I'm missing something, I'm thinkin' its time for a new front hub control solenoid. Your thoughts?
Old Jan 23, 2013 | 06:01 PM
dannyboy950
Try to pull a vacum on the line with a hand vac pump first to eliminate a broke line and or damaged hub seals.
Shelleym62
Mar 5, 2017 07:52 PM
cliffhanger_18
18
Nov 3, 2014 06:54 PM
martinkjc
Oct 25, 2012 12:24 AM
Argus21
Apr 26, 2009 05:43 PM
charon61285
Jul 22, 2007 10:14 PM
