Advice
Old Mar 5, 2017 | 07:45 PM
Shelleym62's Avatar
Shelleym62
Advice
Hello, my truck has heat only coming through the defrost only, I originally thought it may be the control panel, so I ordered a replacement, then under more research I heard it could be the vacuum activated locking solenoid, and was recommended I change it out! Can I have your feed back? Why would this have anything to do with my air flow?
Old Mar 5, 2017 | 07:52 PM
WatsonR's Avatar
WatsonR
The vacuum pump is used for the controls to move from floor to vent to defrost and close the heater valve.
Could be anything that requires a vacuum from the pump to the hubs, looses vacuum and switches to defrost, that's the defaulted position.
bismic's Avatar
bismic
Edit - too slow, oh well!
The climate control flow valves in the dash are vacuum operated.
It may not be the solenoid, you could have a vacuum leak.
There is a small plastic vacuum line on the heater flow control valve under the hood at the firewall (on the passenger side). It may have come off, or you may have another leak as Randy mentioned above.
https://www.ford-trucks.com/g/album/812039
OAS
Jun 3, 2014 09:36 PM
CLINT-THE-GREAT
Sep 13, 2013 04:05 PM
ladiabla74
May 8, 2008 02:26 PM
'91 Silver Devil
Jun 10, 2006 11:18 PM
wildjon300ci
Oct 9, 2002 03:14 PM
