still having carb issues
Old Jan 23, 2013 | 12:38 PM
spikinfool05's Avatar
spikinfool05
well thought i had the highboy running better but guess not. went for a drive today drove all over town not a hickup or nothing. made a stop was inside for twenty mins or so and it wouldnt start. messed around with the points to make sure i had spark got back and it started barely. doesnt want to idle now and when i step on the gas it chugs around and wants to die unless i keep the rmps up. i rebuilt the carb last week and also put a new coil on. still new to carbs as for rebuilding them. motor is a 360 with a 2100 motorcraft automatic trans. i dont have the stove pipe hooked up for the choke as the old one was long gone and broken off in the exhaust manifold. i have power to the choke. any ideas what i could have done wrong when i rebuilt the carb. this is what is was doing before i rebuilt the carb and now its doing it again. i can smell gas like its running rich. idle screws are 1 and half turns out. idle is set at 800 rmps. the high idle is not set right yet but the truck starts fine if its been sitting.
Old Jan 23, 2013 | 02:15 PM
fmc400's Avatar
fmc400
MSEE
The factory electric choke will not run on electric power alone. The electric portion is only an assist and will not kick in until the hot-air stove heats up the choke spring to a certain temperature. You need to get the choke stove hooked back up.
Based on that, I would suspect your choke is closed when you're trying to start the truck warm. There's no heat source to open it up. Check that first.
Old Jan 23, 2013 | 03:05 PM
spikinfool05
that is what i will try next thank you fmc400. now for the fun of trying to get the manfold off with out breaking to many bolts.
Old Jan 23, 2013 | 05:16 PM
fmc400's Avatar
fmc400
MSEE
You shouldn't have to remove the intake for this; on all the ones I've seen the choke stove pipe is secured to the manifold with a small plate and two bolts. I'm not sure if a 360 would be any different. The choke stove is just a coiled tube, flared on the end that threads to the choke housing and barbed on the end that connects to the air horn via a short length of vacuum hose.
Or, maybe I misinterpreted what you said.
Old Jan 23, 2013 | 05:50 PM
spikinfool05
mine goes to the exhaust manfold. there is a hole in the passenger side. some one at some point broke the stock one off i might be able to get a angle drill in there to drill it out. just not alot of room between the ac box and the manfold.
Old Jan 23, 2013 | 06:29 PM
tasboj's Avatar
tasboj
Wen I Rebuild my motor I drilled the two holes *** close to the same size, and then I bought some hard steel brake line and made new ones, worked out great, but I had the old pisces to match the diameter.
Old Jan 25, 2013 | 11:21 AM
wdfp's Avatar
wdfp
Can't you just change the thermostat to a full electric one Like holley or demon use?
oft
Jan 1, 2015 01:29 PM
Nathan Plemons
Jun 30, 2009 06:44 AM
the kid
Dec 26, 2007 01:06 AM
packrat56
Nov 2, 2004 11:38 AM
Franklin2
Jan 20, 2002 10:11 PM
