"Haunted" Temp gauge
Old Jan 22, 2013 | 08:54 PM
Explorer220K's Avatar
Explorer220K
Hi all.....96 Explorer XLT 4X4 4.0 pushrod V6
Have noticed temp gauge hardly ever moving off full COLD mark. Seemed to always take a while to warm up, and have decent heat out of vents...wont run you out of the truck but is "ok"...so I'm thinking thermostat might not be closing.
So I swaps out T-stat (195 degree), re-fill radiator, fire it up, set heater to high, and wait for full warm up....temp gauge begins moving.....gets to halfway, then eases down to about 1/4. I go out to run errands.....gauge runs up 3/4....drops down.....goes up, then drops down...it's all over the place. I'm stumped and turn to the collective knowledge here-in for guidance/ideas. Thanks in advance.
Old Jan 22, 2013 | 10:13 PM
steve(ill)'s Avatar
steve(ill)
still sounds like bad thermostat. I assume you have all the air out of system ? Park with the nose uphill a foot higher than back end. That will make air go toward the radiator and not trapped on top. I cut a high heater hose on my F150 and installed a plastic flushing TEE.. that helps to blead out air when filling the antifreeze. An air pocket in the system can give up- down readings like you suggest.
Old Jan 23, 2013 | 08:51 AM
Explorer220K
Will give that a try this evening.
Old Jan 23, 2013 | 10:23 AM
KhanTyranitar's Avatar
KhanTyranitar
Thats why I only buy genuine Motorcraft thermostats.
1owner72
1997 - 2003 F150
13
May 29, 2016 09:05 AM
nash22
58
Dec 27, 2014 02:52 PM
gcpommom
Aerostar
Dec 13, 2011 09:04 PM
Brawl
1983 - 2012 Ranger & B-Series
Mar 26, 2006 09:26 AM
h-duty
Jan 1, 2004 04:58 PM
