Heater dosnt work but AC does???
Old Jan 21, 2013 | 07:07 PM
ljemmer465's Avatar
ljemmer465
i have been hearing diffrent things whats wrong but its cold here in the winter and i have 6 kids so i hope some one can help. I need my heater. My heater dosnt work. it will turn on and blow out air but it never gets hot not even a little bit. my AC kicks @$$ but heater dosent work. what can it be???
Old Jan 21, 2013 | 09:16 PM
jh818's Avatar
jh818
Maybe blend door is stuck?
Old Jan 21, 2013 | 09:41 PM
ljemmer465's Avatar
ljemmer465
thank you for the reply. whats a blend door and how would i check it?
Old Jan 22, 2013 | 08:10 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Coolant level low or stuck thermostat.
Old Jan 22, 2013 | 08:21 AM
tadhg's Avatar
tadhg
You need to check your engine temperature first! If that isn't up, then you won't get any heat out of the system, because the engine supplies the heat for the HVAC.
If the temperature is up, you may have to have the heater core flushed out, or replaced, because the coolant, isn't getting into it. You'd be surprised what kind of gunk builds up in the coolant system and clogs those very small passages. Every 3 years is a good rule of thumb...
Old Jan 22, 2013 | 08:23 AM
jh818's Avatar
jh818
A blend door is a flap/door that moves to close off or open up the air direction to control the temperature of the air going through the vents. It can get stuck sometimes or the actuator could fail. It's located behind the dash somewhere near the glove box, center dash I believe. There have been write ups on the subject recently either here or on the Super Duty or V10 forum. I don't recall which one, sorry.
Old Jan 22, 2013 | 08:28 AM
jh818's Avatar
jh818
Good point.
I beleive there is also a valve that is vacuum activated that shuts off the coolant to the heater core when you turn on max AC. It's on the passenger side just above the valve cover near the AC accumulator.
Old Jan 22, 2013 | 08:29 AM
Truckie256's Avatar
Truckie256
these are 2 easy inexpensive places to start...
blend door and replacing heater core can get pricey it you need someone to pull dash for you...
Old Jan 24, 2013 | 04:22 PM
ljemmer465's Avatar
ljemmer465
Thank you all for the info. I will check it all out. I dont think its the heater core, i have had ones go out on me before and its not showing the symptoms. When I turn the heater on I check under the hood all the pipes that lead from the heater core are all freazing cold like the AC is on. Also when i turn the heater on in the back the air comes out nuke warm. I get a flush every year, the fluid it full and there is a new thermo.
Old Jan 25, 2013 | 01:36 PM
Elmo154's Avatar
Elmo154
jh818 is right
Don't wast your time checking heater cores, blend doors, or thermostates until you replace this simple bi pass valve. It is an easy fix.
Old Jan 26, 2013 | 10:42 PM
ljemmer465's Avatar
ljemmer465
Replacing the Bi Pass Valve...how would I do that? Could it be the temp control, to switch it from hot to cold?
Old Jan 27, 2013 | 08:17 AM
Elmo154's Avatar
Elmo154
Location of valve
Try this post. There is a picture of the valve. It is located on the passenger side near the PCV valve. You will see a vacuum hose conected to the coolant lined. The valve simply plugs into the hoses and is secured by the pressure clamps.
https://www.ford-trucks.com/forums/1...l#post10563275
Old Feb 2, 2013 | 05:29 PM
Elmo154's Avatar
Elmo154
What did you find out?
Just curious. What did your problem end up being?
92will
Oct 5, 2016 06:25 AM
baja4dogs
Feb 7, 2016 10:36 AM
jh818
Aug 21, 2012 07:38 PM
sboyd2224
1983 - 2012 Ranger & B-Series
Jun 8, 2011 10:10 PM
leardvr
Apr 6, 2010 08:35 AM
