Water temp problems
Old Jan 21, 2013 | 05:17 PM
specops12's Avatar
specops12
Water temp problems
I have a 1987 f150 it was recently rebuilt and I put aftermarket sensors on it and the gauges were reading fine until I had to replace the battery cables because it left me sitting then both oil pressure and water temp were reading higher and someone suggested it might be the alternater o I check it and replaced that then I took the sensor out and test it wit a lighter and 2 seconds after a lit it the gauge was topped out as soon as I took it off it went back down to the bottom so I replaced the sensor and drove it less than a 1/2 mile and the gauge went way above its top mark at 250 does anyone know what might be causing that to happen?
Dman130
78
May 31, 2017 12:50 PM
dennisb56
Mar 16, 2012 05:19 PM
gasman6674
Feb 27, 2012 02:45 PM
johnsjsj
Sep 18, 2007 10:07 PM
joners
Dec 21, 2005 12:48 AM
