P0402 & P132B code
Old Jan 27, 2013 | 02:35 PM
BLADE35's Avatar
BLADE35
I assume you did the Data Log while driving
If this^^^is True those numbers are ALL Biased
The sensors values need to be Taken under these conditions below
OPERATING VALUES
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to And EOT at 185* or higher
A/C OFF
#1-------KOEO=Key On Engine Off =record EACH sensor value and POST IT!!
#2-------Low Idel (truck idel on its own)=record EACH sensor value and POST IT!!
#3-------High Idel (2500RPM)=record EACH sensor value and POST IT!!
ALL^^^^^^^^^^^^^^^^^^^^^^^^^ Taken in Park or Nuetral
All the sensor values I have need to be taken under this Condition as they will be the most Accurite
When you take values when driving there is just to much varibles that can come into play and Skew the Results
Like
Speed
Load
was the road Leval or uphill or down hill
so the best way is just in your driveway in Park Nuetral
Data Logs are Good for Intermittened problem Finding
But for general just Post the 3 values per each sensor to start off with
Old Jan 27, 2013 | 02:42 PM
Edogsf350's Avatar
Edogsf350
The values in the data log are at 0 MPH but not at operating temps. I will get up to temp and repost the values. Exactly which values do u need?
Old Jan 27, 2013 | 03:03 PM
BLADE35's Avatar
BLADE35
Oh I see all that in my last post was just general info
So since its a Boost DTC we are Mainly looking at Pressure Sensors and being upto temp may Not affect those unless something shorts out when it gets to Normal operating temp
Since you cleaned those sensors and EGR Valve and cleared the DTC and they Have Not returned you may have Solved the Problem
I wouldnt stress to hard unless the DTC come Back
Keep an eye on on
Boost
Old Jan 27, 2013 | 03:33 PM
Edogsf350's Avatar
Edogsf350
I'll keep a eye on it . And make a new post if something comes back. So until the I'll put this thread to rest..
Old Jun 7, 2016 | 06:10 PM
br3363's Avatar
br3363
I know this thread is OLD but I am having the exact same problem.
When you guys say the EBP value is inferred are you saying that my AE Scanner will never pick up a value on the EBP Signal. I have replaced the Sensor and pigtail with NEW ONES. I have pin tested the 3 wires from the EBP to the PCM connector and they are all connected.
The truck starts right up but has a mis that started suddenly at a stop sign that comes and goes. NO CODES, when i first bought the truck, it ran rough when cold but when it passed like 140 degrees it ran great.
buddy told me FICM was bad even though it passed all the voltage tests.
FICM replaced no help
I did head gaskets, studs, oil cooler,egr welded shut both ends. no tune.
I read that the EBP also controls injector timing in the bible, that is why i am thinking this is my problem, should i buy a PCM?
Thanks, jim
Old Jun 7, 2016 | 08:54 PM
BLADE35's Avatar
BLADE35
Thanks, jim
Best to start a new Thread
Post year and exact DTC Found
Your EGR Delete could be causing them and may have other problems
you shouldn't be getting P0402 with a Delete But do you have it??
P0402 – Exhaust Gas Recirculation Flow Excessive Detected
fdaugher
Apr 27, 2012 10:04 PM
mushman
Nov 12, 2011 04:25 PM
fdaugher
Jan 2, 2011 12:45 PM
rcknrbn
Sep 9, 2008 08:47 AM
zss42002
Jun 3, 2008 08:37 PM
