What year steering columns are interchangeable without modification?
Old Jan 20, 2013 | 11:04 AM
67F250RET's Avatar
67F250RET
I have a 1967 F250 Camper Special with a cruise o matic tranny, the steering column needs virtually every part to repair it to original and working condition. I was wondering what years are compatible with my truck so I can possibly just swap it out. Thanks
Old Jan 20, 2013 | 11:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
With or without P/S?
The upper/lower steering column bearings (C3DZ-3517-A) and sleeves (B1AZ-3518-A) are available from Ford as is the shift collar (D5TZ-7228-A).
The rubber bushing and insulator (C5TZ-7343-A kit) located on the selector lever at the bottom of the column under the hood is obsolete. 100's availabe NOS
Old Jan 20, 2013 | 01:04 PM
67F250RET's Avatar
67F250RET
Without P/S, I haven't found the most basic element...the shifter arm. I've seen several shifter arm ***** but not the arm itself. Any ideas?
Old Jan 20, 2013 | 03:12 PM
NumberDummy
What finish does the lever have now, painted or chrome? I think the original was painted (parts catalog doen't say). The **** was black originally.
D3TZ-7210-C (replaced C5TZ-7210-W & C9TZ-7210-F) .. Chrome A/T Shift Lever w/Plastic Chrome **** / Obsolete ~ 17 available NOS (6: Don Sanderson Ford in Glendale AZ - 623-842-8643).
Applications: 1973/77 F100/350 & Bronco / Service Part Replacement: 1965/68 F100/350 & 1969/72 F100/350.
I couldn't find the C5TZ-7210-W original or C9TZ-7210-F. So you'll have to use the chrome lever and you may have one now, as the original was replaced in 1969, then again in 1973.
Old Jan 21, 2013 | 12:00 PM
67F250RET's Avatar
67F250RET
The lever was ripped off long before I got the truck so I don't know. Thanks again for the info, super helpful.
KSousa
Mar 18, 2018 11:58 PM
LIL LU
Nov 7, 2017 07:41 PM
67F250RET
Jan 18, 2013 08:53 PM
Little Wolf
Nov 28, 2011 04:04 AM
Macon ACE
Aug 1, 2007 05:05 AM
