Stuck in park. Don't think it's shift collar - Ford Truck Enthusiasts Forums
Old 03-17-2018, 12:56 PM
KSousa
KSousa is offline
KSousa is starting off with a positive reputation.
1972 F100, factory automatic on the column.
Won't come out of park.
I've read a lot of posts here that point to the shifter collar being notorious for problems.
However, I have removed the steering wheel, removed the shifter column collar and shift lever completely and removed the linkage arm from the firewall side to the transmission,.
At this point, I would think that I could grab the arm on the firewall side and roll it back and forth but she's still stuck.
Anyone have other ideas on what I'm doing wrong?
thanks
Old 03-17-2018, 01:28 PM
willowbilly3
willowbilly3 is offline
willowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to all
At this point your diagnostic process seems about right. Unless it's sitting on a steep grade, my guess is an internal problem in the transmission. Pull the pan and have a look.
Old 03-17-2018, 02:11 PM
KSousa
KSousa is offline
The transmission shifts just fine by hand.
it's the column and column linkage arm that I can't get to move.
Old 03-17-2018, 07:35 PM
willowbilly3
I guess I misunderstood what you were moving under the hood. Bite the bullet and just pull the steering column so you can disassemble and inspect it. You can't get it all the way apart in the truck.
Old 03-18-2018, 11:58 PM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
I sent you an email.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
