Ok guys I've searched a hundred threads and can't find this answer. When I'm s
Turning the wheel and the body moves before the wheel does, what are some possible diagnosis. I have a 6 inch lift and 35x10.50 tires.
You don't say and I've forgotten what year / series truck but all F150s with coil springs have track bars? 6" is a big lift.
Not sure just what you mean ..... but if the axle is leaned back so there is some caster, like if a line drawn through the ball joints would hit the ground
in front of the tire center (positive caster) .... then as soon as the wheel (on ground) starts turning left or right you would .... should ....
feel a shift if sitting in the cab stationary due to "caster". If there was no change made in C-bushings or the radius arm rear not lowered when the lift
was installed, then you may have zero or even negative caster. Some positive caster is a good thing.
If however, the cab and frame are say ... shifting to the right before there is any movement seen at the road wheel when the steering wheel is turned,
then I would say track bar bushings or perhaps the track bar mount itself over on the left frame rail is loose or the frame cracked.
Get under the front end laying on your back and have someone rocking the steering wheel left and right as you inspect track bar bushings and watch for
any deflection in the track bar mounts on left frame and right side axle tube.
What are we working on, besides a 73-79 fseries? f150, f100, f250, f350, I am going to say probably 4x4 with a lift. 1/2 ton needs front end rebuilt, all new bushings, and check ball joints, tie rods, wheel bearings, brakes, and be sure that that thing is road worthy, a 1/2 ton is a lighter suspension that the 3/4 tons for that much tire and lift. I would not drive it till it is fixed. Not road worthy.
From some of his other threads, it "should" be a 1977 F150 4x4.
Sorry guys yes, it is a 1977 f150 4x4. All the bushings in the front are good. Previous owner swapped the front end over to the 78-79 steering components. I went through it everything is tight. There is some slack on the shaft the enters the steering gear box when turning the wheel it moves a lot before the pitman arm does, least a quarter to half a turn.
If the shaft moves before the pitman arm, then its in your shaft like you said. Depending on your column set up, check your rag joint or your steering shaft u-joint. There can also be play in the gearbox itself between the pitman and sector shaft
Well new shocks are not going to fix this problem, as far as matching whats shocks on it now, measure them.....
i know the new shocks wont fix the steering gear box issue. but im hoping that the new shocks with new rubbers will help witht he body roll. im thinking ill probably need to replace the steering box as well. but figured the body roll issue might be a little more serious than the loose steering.
