Assembly Questions
Old Jan 19, 2013 | 08:33 PM
GaryLP's Avatar
GaryLP
Assembly Questions
Hello All, I just got my cab finally painted yesterday, it is a '78 F-150, 460, long box 2 wheel drive. I have a couple questions I hope someone can answer before I start putting it back together.1. On the inside of the engine compartment where the speedometer cable comes thru, is there a rubber plug or grommet that that goes in the hole? It is roughly 1 1/8 in size. 2. Has any one used the roll of body to frame webbing that LMC sells to go between the frame and where the pick up box mounts? Does it throw the body lines off? 3.Has anyone ever bought LMC's tinted vent windows and tinted side glass? I hope someone has answers as I can use all the help I can get.
Old Jan 19, 2013 | 11:29 PM
jtindale's Avatar
jtindale
There should be a grommet that wraps around the speedometer cable where it goes into the cab.
I have a picture of the cable and grommet here:
https://pqqitw.dm1.livefilestore.com...633.JPG?psid=1
Old Jan 19, 2013 | 11:52 PM
7636074460's Avatar
7636074460
the cab does not really contact the whole frame because it should ride upon the mount rubbers, there should be a small gap most of the way. you could put something on the frame like playdoh or something, set the cab down and youll see if theres anywhere you wont want to lay the webbing because the putty would be squooshed out. im not familiar with the webbing (i know of it) if its compressable or not?
either way i doubt it would throw off body lines. the inner fenders adjust up/down for fender alignment and also the bottom fender bolt has some play too. the only one to worry about would be the bed and you could very easily shim that up
Old Jan 20, 2013 | 10:02 AM
bucks77ford's Avatar
bucks77ford
I bought the side glass and was happy.
Old Jan 20, 2013 | 10:41 AM
gpence's Avatar
gpence
I have your little groumet for the speedo cable sitting here, why not just run the truck over to Protint and have them tint all the windows when you finally get the truck back in one piece, and what's this webbing you speak of?
Old Jan 20, 2013 | 10:23 PM
GaryLP's Avatar
GaryLP
Thanks, Every one for their help. Greg, webbing is found on page 10 of LMC's catalog, part # is 49-9305. You get 30 feet to mount the box on..........
Old Jan 20, 2013 | 11:21 PM
gpence's Avatar
gpence
Yep um I pitched my lmc catalog in the trash after I bought a grill shell from them that didn't fit worth a crap. Lol
Old Jan 21, 2013 | 08:15 AM
bucks77ford
The "tinted" side glass has the "greenish" tint to it that really is barely noticeable. It's not darkened tint.
You'll hear it over and over that LMC sells crap. Some things they do and some things are quite good. You are going to find that with most companies quite frankly unless they produce their own parts. LMC just distributes parts. I've gotten parts from them with Dennis Carpenter packing (which is OEM) and parts with "made in Taiwan". As we all know Taiwan parts are hit and miss. When it comes to aftermarket, the you get what you pay for comes into play more times than none. I've had the same thing with NPD and Broncograveyard. Parts packaged with Dennis Carpenter packaging and what looks to be like LMC packaging. So, what it boils down too is if the parts are aftermarket or OEM. You are going to spend more for OEM parts, but they are going to fit like factory. Aftermarket parts are cheaper for a reason. If a parts requires "fit" like body parts, be aware that it might not be very good.
Like I said, I bought the side glass from them and was happy and very well packaged.
Old Jan 21, 2013 | 10:43 AM
gpence's Avatar
gpence
Yeah I've gotten a few things from LMC over the years for both my 77 F150 & my 86 bronco. Body parts do not fit worth a Damn. The weather stripping & most of the interior stuff fit fairly well on both trucks
I was just giving the Garbear a hard time because he's almost like family.
Old Jan 21, 2013 | 12:07 PM
bucks77ford
All dentside owners need a hard time every now and then.
Obowersox26
Jan 25, 2016 04:13 PM
ditz
Dec 8, 2007 03:39 AM
88fordf150
Jun 2, 2005 09:28 AM
flatdeck 82
Apr 10, 2004 10:34 AM
