bleeding clutch
Old Jan 19, 2013 | 01:19 PM
b_man360's Avatar
b_man360
bleeding clutch
i have a 97 mazda b4000. i broke the head of the bleed screw off on the slave cylinder and i need to change my master cylinder. is there a way to bleed the clutch without using that bleed screw? or can i get away with just bench bleeding the master cylinder and hoping no air gets in the slave when i disconnect and reconnect the line.
i dont realy want to drop the tranny to get at the slave and dig the bleed screw out, since i just changed the slave a few months ago and it was a big pain.
Old Jan 19, 2013 | 03:51 PM
f5fordgirl's Avatar
f5fordgirl
You might unhook the line at the master and bench bleed it, before you hook it back up, make sure the line is full of fluid.
Old Jan 19, 2013 | 06:02 PM
b_man360's Avatar
b_man360
ya thats what i ended up doing. but i think some air got in when i reconnected it.
at least i got a somewhat working clutch now. i might try a vacuum pump at work and see if i can suck the air out the top.
Old Jan 19, 2013 | 06:36 PM
drb1956's Avatar
drb1956
this slave/master design is one of the worst-if you can get the clip off of the pedal assy part of the master,(you have to remove clutch safety switch and pedal) just pull ever so slightly out on rod, and the air should be gone, gently push in, put clip back on, and reassemble pedal switch and reattach pedal...
x_man586
15
Jan 1, 2014 11:18 AM
bigfish6025
17
Sep 9, 2011 09:32 PM
srumble
Nov 17, 2007 06:36 PM
frederic
Jan 5, 2006 07:58 PM
frederic
Jan 5, 2006 12:03 PM
