oil pressure issues
Old Jan 19, 2013 | 06:38 AM
94_4x4_912's Avatar
94_4x4_912
oil pressure issues
I have a 2003 f-250 with a 6.0. It was manufactured in 12/02. My oil pressure goes to 0 at a idle at normal operating temp. It does not do this all the time its an intermittant issue. Truck runs fine though. no other issues. Could it just be the EOP switch? I noticed it is wet with leaking oil. Any help is greatly appreciated on this matter.
Old Jan 19, 2013 | 07:37 AM
stinks the truck dog's Avatar
replace leaky switch
Old Jan 19, 2013 | 12:13 PM
dannyboy950's Avatar
dannyboy950
You will also want to change the pig tail to that sensor. Solder and shrink wrap those splices no butt connectors please.
Old Jan 19, 2013 | 01:20 PM
Misky6.0's Avatar
Misky6.0
I had same thing, replaced the eop switch and
Problem is gone. Mine would drop to 0 at 70mph sometimes too, so i knew i had oil pressure. The oil supply tube is in the way, so you might need to remove it to get a deep socket in there.
Old Jan 20, 2013 | 08:36 AM
94_4x4_912's Avatar
94_4x4_912
thanks guys. I'll let yall know if it fixes my issue.
Old Jan 20, 2013 | 09:09 AM
dannyboy950
Are you talking about the ICP or the dash gauge? Dash gauge only registers 7 psi and it's signal is not even seen by the pcm. Located in the oil cooler cover just behind the filter houseing. A single wire connector.
Old Jan 20, 2013 | 11:42 AM
cheezit's Avatar
cheezit
nither they are talking about the oil sender.
Old Jun 18, 2025 | 05:24 AM
8pack's Avatar
8pack
WRONG FORUM POST. POST DELETED
Powermonger
21
Sep 18, 2011 06:08 PM
bfnavarrete
Nov 5, 2010 09:39 PM
Toyman
Nov 30, 2009 08:57 AM
fastone
Apr 25, 2008 08:07 AM
ronha2
Nov 18, 2006 10:03 AM
