Lub dub hiss
Old Jan 18, 2013 | 11:12 PM
blackestate's Avatar
blackestate
Lub dub hiss
Ok, after changing the plugs etc. it still has a miss, and rough idle.
When I was under the hood listening, I noticed that sometimes when it misses there was a hiss sound. I opened it up at the air cleaner, and I am hearing like a heartbeat when it misses, lub dub, then a hiss.
Is this a valve? bus since it is occasional, is it a lifter? I assume this has hydraulic lifters. And if it is a lifter, can I clean it with a little seafoam in the oil?
Could this be a cam/crank sensor starting to fail?
pulling the connections to the coils, and the injectors all provide a constant miss. this is driving me nuts,
Thanks for any input you can give.
Doug
timbersteel
20
Jul 18, 2012 02:09 PM
slafronza
1997 - 2003 F150
Mar 13, 2010 09:36 PM
jwgeorge
16
Aug 24, 2005 10:08 PM
SlickRanger
4 Cylinder Engines
Nov 3, 2004 09:36 AM
mrwizard
Mar 15, 2003 07:43 PM
