Flat spots on cam?
Old Mar 14, 2003 | 08:32 PM
mrwizard's Avatar
mrwizard
Angry Flat spots on cam?
OK, so I've been having a rough idle problem the last few weeks. No codes. Changed all the usual tune-up type stuff. No improvement. Since I get a discount because my daughter works at a dealer, I finally broke down and took it in.
What I get told is fuel injectors are dirty and need to be cleaned. Fine. MAP sensor is way out of range. OK, fine. He says all the plugs like fine. I know, I just changed them, but the old ones looked fine too. He says the rest of the basic stuff looks good. Then he tells me my compression is at about 150 PSI, but he's pretty sure my cam has some flat spots on it. Huh? I've only had the truck since last July, and it's run great until this rough idle thing started a few weeks ago. I of course have no way of knowing how the truck was treated before. I'm assuming it was used to either tow or haul some fairly heavy weight considering the overload leafs AND the coil-over shocks on the back.
Has anyone else had a problem with cam lobes flattening out, but the engine still seems to run OK? I guess I'm just going to have to see if the MAP sensor and cleaning the injectors smooth out the idle.
Old Mar 14, 2003 | 08:39 PM
vman's Avatar
vman
Flat spots on cam?
I thought they went to roller cams by 95. Only older chevs wear out cams. It would probably start popping out the exhaust or intake if you started to round a lobe.
Old Mar 15, 2003 | 12:24 AM
mrwizard's Avatar
mrwizard
Flat spots on cam?
No popping or anything like that. It has just been shaking at idle. Actually, even while driving when the RPM's are under 1500 or so you can still feel it. Anything over that and it's just as smooth as ever.
I thought the engines were roller by '95 also. Does anyone know for sure?
Old Mar 15, 2003 | 10:50 AM
vman's Avatar
vman
Flat spots on cam?
Well if it smoothes out you know it's not the cam.Rollers don't wear out and I'm pretty sure thats what you have.
Old Mar 15, 2003 | 06:55 PM
mrwizard's Avatar
mrwizard
Flat spots on cam?
Well, so now they say the cam is fine, but I have a vacuum leak in the intake manifold gasket.
And no, the MAP sensor and cleaning the fuel injctors didn't help at all.
Old Mar 15, 2003 | 07:43 PM
Bob Ayers's Avatar
Bob Ayers
Flat spots on cam?
The best way to check for a "wiped" cam lobe is to pull the valve
covers, and watch the valves open. If you have a "wiped" cam
lobe, you will see the valve barely open....
kedwinh
1983 - 2012 Ranger & B-Series
Sep 18, 2012 12:06 AM
rkurkowski
May 13, 2011 11:01 PM
1pump
18
Sep 11, 2007 11:55 PM
MikeFlorida
Feb 18, 2007 05:23 AM
Old_Paint
Jul 16, 2006 10:04 AM
