Need wiring help badly!!!!
Old Jan 18, 2013 | 09:13 PM
REDNECKIT's Avatar
REDNECKIT
I'm almost finished swapping my 1992 7.3 into my 97 f350. But when my buddy and I took her out of the old truck he went crazy and took all the wiring off the engine before I could catch him. I have most of it figured out like glow plugs alternator and injector pump but I'm totally lost on everything else. Took it for a test drive and my speedo, oil pressure, coolent, fuel gauge don't work. Completely lost and would really appreciate some help
Old Jan 18, 2013 | 10:09 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
this will get ya headed in the right direction;
Old Jan 21, 2013 | 05:32 PM
REDNECKIT's Avatar
REDNECKIT
Thanks tons. I got another question for ya if you don't mind. I've connected everything up the right way and my instrument cluster is acting screwy. For example, my temp, oil pressure, and fuel gauge arn't working. And I got my speedo and Odometer working and now my RPM gauge suddenly stopped working. All the grounds that I can find I've grinded down and reground, but all this stuff was working on my old truck before I took it out.
Old Jan 21, 2013 | 06:59 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
did you put the '92 cluster in the '97? i am pretty sure you need the engine specific cluster.
the idi's and psd's use a different "method" for getting info to the gauges.
Old Jan 22, 2013 | 05:41 PM
REDNECKIT's Avatar
REDNECKIT
Yea, every bit of wiring from headlights to the tail lights is all from the 92. Is there any way I could check the senders and the gauges? Like I said they were all working. Ugh, wiring is so confusing.....
BigCountry1978
17
Jul 5, 2016 12:43 AM
Maggie T
Jan 29, 2014 09:06 AM
Scifi266
Nov 5, 2011 08:06 PM
Pele
Dec 20, 2006 09:16 PM
bigric
Feb 27, 2003 10:07 PM
