Hey guys i have a question that i just cant figure out. im trying to figure out my current compression ration on my 400. bin on the computer searching for a couple hours an i cant really come up wit anything. theres gotta be some good guys that no what there talkin about on here so i can get this sraight an choose another cam. everythings stock except the pistons which i have not a clue what kind they are but there stamped .040 on them. so heres what i got so far.
these are the exact pistions that are in the truck
If anyone can help i would greatly appropriate it. i had this motor appart once already to do the top end which was only done on a tight budge.
thanks
Ron
Thanks hio i appreciate it. Yea i no it was a .030 over i was just to give you guys a under standing of wat it looks like. But idk what i should do the cam i would like to get i need a 9:1 compresstion ratio which i doubt that just .040 would do that
An overbore would reduce compression because there is more cylinder volume at TDC with the same CC in the heads. To physically increase compression would mean flat top or pop-up pistons.
To trick the engine into more compression with the cam, the intake valves would have to close sooner. I'm no cam expert so I think ya ought to contact CompCams and get their input on your build. Their site has a provision to send an email or even discuss it in a forum.
False! There will be a greater amount of air drawn in to be compressed. Every .030 over adds about 10% of a point.
I stand corrected! I'm thinking about the piston at TDC and wasn't thinking volumetric:
Originally Posted by Mark Kovalsky
You're both wrong.
Compression ratio is the ratio of cylinder volume with the piston in the bottom of the bore divided by the cylinder volume with the piston at the top of the bore.
When you bore the cylinder it's volume is larger. Your volume increases when the piston is at the bottom of the bore a lot more than it increases with the pistion at the top of the bore. If the piston comes to deck height or higher then the volume with the piston at the top of the bore does not increase, but the volume with the piston at the bottom is larger. That makes the compression ratio higher with a bored cylinder.
Originally Posted by jimdandy
Yep, all things remaining the same except bore, compression will be higher, but not that much higher. jd
Sort of.
Just as an example, If your engine operates at a volumetric efficiency of 75%, and each cylinder is 500cc, the amount of air drawn in would equate to 375cc at atmospheric pressure. If you increased the cylinder volume by 10%, to 550cc, and the volumetric efficiency stayed at 75%, you'd then be drawing in the equivalent of 412.5cc. So for a cylinder volume increase of 10%, the increase of air volume would be 9.09%.
Thanks guys for the info regardless i think comp will tell me i gotta find the comp ratio before they give me any info i talked to them on my first build an they gave me the cam i have now an i calc the overlap an its only 1. The thumper cam that needs has a overlap of 35.5 which will be a big step but i have a good knowlege with motors. Bin around them since i can remember. We dont take out cars or toys to the dealer we figure out the prob an fix it.
Hey guys i just wanted to let us no i used summits cr cal just to ballpark it an it cam up 8.5:1 i no this might not be right but lets just say it was. My other question now is what is the best way to bump that 8.4:1 to 9:1?
As far as I know TMyer inc has the only flat top pistons for a 400. I believe it put mine around 9.3:1. There are other ways to increase comp ratio, I think there are some Aussie cleavland heads that bump it up too? Check out the 335 engine forum here. It's a great place to learn about 400s. Good luck to you.
