78 ford 400 6.6l newbie - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 05-25-2018, 09:17 PM
Clovis123's Avatar
Clovis123
Clovis123 is offline
Clovis123 is starting off with a positive reputation.
OK guys this is my first post. Bronco enthusiast. We have recently acquired a ford 400 6.6l. Wanting to increase the low-end torque i.e. Shaving the deck and boring out the cylinders to a larger size. We have been doing hot rod but 4 x 4 at the same time and looking to increase the low-end torque going to get thumper sound like you would with a cam but addressing the actual compression issues. Anybody have any thoughts? I know with the stock is. I'm not planning on going to get my degree in mathematics LOL was hoping somebody could give him advice for the largest bore to give at least one point plus a better compression any advice would be helpful thank you guys. Now the caveat to all of this is that it's going into a 64 Ranchero sitting on an 85 full-size bronco XLT frame. We think it's an interesting combination and worth doing and worth doing right. Any advice appreciated.
Old 05-25-2018, 11:57 PM
SDDL-UP
SDDL-UP is offline
SDDL-UP is starting off with a positive reputation.
Check out TMeyerINC.com. He has pistons that will bring the compression up to about 9.3:1 and knows A LOT about these engines. More compression and a healthy cam and you might be surprised what the 400 can do.
Old 05-26-2018, 11:02 PM
78Broncoinpieces
78Broncoinpieces is offline
78Broncoinpieces is starting off with a positive reputation.
link says the domain name tmeyer is for sale
Old 05-28-2018, 10:44 AM
Redark1
Redark1 is offline
Redark1 is starting off with a positive reputation.
If you find a set of Aussie heads it will bring up the compression. Mine has flat tops down in the bore at least .060-.090 and I ended up with almost 11to1. Just bore it for a fresh bore and call it good. Work with the cam from there to make power where you want it.
Old 05-29-2018, 06:03 PM
5851a
5851a is offline
5851a is starting off with a positive reputation.
Old 06-10-2018, 10:02 PM
outlawbob
outlawbob is offline
outlawbob is starting off with a positive reputation.
aussie heads, roller cam ( no break in like a flat tappet cam) aussie heads will run you about 1000-1500 there on ebay and there is a aussie cylinder hear web site.
UKblue2
2017+ Super Duty
03-06-2017 07:15 PM
stignatious
Tennessee Chapter
10-27-2014 11:34 AM
stignatious
1997 - 2003 F150
10-19-2014 08:52 AM
rambaseball45
5.0L Coyote
45
08-27-2010 07:58 PM
mbookout
11-06-2005 08:42 AM
Quick Reply: 78 ford 400 6.6l newbie
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service About Us
© 2018 MH Sub I, LLC dba Internet Brands
