Sponsored by: Real Truck
Heater control
Old Jan 18, 2013 | 01:27 PM
jacsent's Avatar
jacsent
Heater control
I have not had any air blowing out of any other area that the defrost.When I select floor, HI, all blows from windshield defrost, similarly no matter what setting I select, only blows out defrost.
How can I troubleshoot this? Where to start? Control unit in dash? stuck vent flap? I have heard that the controls were a common problem... but I guess the question is how do I determine if that is the actual issue?
Much appreciated
Old Jan 18, 2013 | 03:40 PM
iron1951's Avatar
iron1951
On my 04 F250 blowing only out the defrost usually means a vacuum leak. In my case it was in the ESOF 4x4 system. Check to make sure you have vacuum and there is no leaks.
Old Jan 18, 2013 | 08:18 PM
jacsent's Avatar
jacsent
That may make sense, does that have control of the automatic 4x4 at the hub? Right now the only way I get 4x4 on the fly is if my hubs are locked. I figured I had a faulty hub and haven't taken the time to check it out.
Old Jan 18, 2013 | 08:32 PM
JamesB128's Avatar
JamesB128
You most defiantly have a vacuum issue. it's quite easy to trouble shoot. The first question is do you hear the vacuum pump run when the key in the on position?
Old Jan 18, 2013 | 08:33 PM
AzPete's Avatar
AzPete
Yep....sounds like a bad vacuum hose to the hubs OR a bad seal in the hub.....does the vacuum motor run when you turn on the key after it has sat for a while?
Old Jan 18, 2013 | 08:48 PM
iron1951's Avatar
iron1951
On the passenger fender there should be a PVH solenoid (Pulse Vacuum Hub Solenoid). You might want to disconnect this from the vacuum system and plug the line. The idea is to try and eliminate the ESOF vacuum system from the rest of the vacuum that runs the heater system. If the air blows out from other areas, you know where your problem is. Because 4x4 only works with hubs locked, sounds like your vacuum leak is in the ESOF vacuum system and not with the heater system. If you are not interested in fixing the ESOF system at this time, leave it isolated from the vacuum system (plug open lines to prevent dirt entry) and continue to run your automatic 4x4 with the hubs locked.
Last edited by iron1951; Jan 19, 2013 at 07:53 AM. Reason: spelling error on a key word
Old Jan 19, 2013 | 03:05 AM
Yahiko's Avatar
Yahiko
I have one of these
Mityvac/Silverline elite vacuum pump test kit (MITMV8500) | Vacuum Pump Brake Bleed Kit | AutoZone.com
It is very handy for doing testing on vacuum systems and for bleeding the brakes.
Here is a cheeper one
OEM/Liquid siphoning vacuum pump kit (25136) | Vacuum Pump Brake Bleed Kit | AutoZone.com
Let us know if you need help and how you fixed it.
Sean
NOTE: PM me if you want the 06 copy of the vacuum schematics.
Old Jan 19, 2013 | 07:26 AM
jacsent's Avatar
jacsent
Well I have heat control now. thanks a lot guys turns out it wasn't a vacuum leak.
I just looked at the pump and the connection, I squeezed a little bit tighter and sure enough the pump fired right up and now I have controls.
Should this pump be running all the time?
If not maybe I do still have a vacuum leak somewhere but for now at least My wife can have warm feet!
Old Jan 19, 2013 | 07:52 AM
greentree ford's Avatar
greentree ford
pump should not run all the time
Old Jan 19, 2013 | 07:53 AM
iron1951's Avatar
iron1951
My diesel vacuum pump does not run all the time. It shuts off once the vacuum canister is full of vacuum. If yours is running all the time there is definitely a vacuum leak. I would be afraid of burning out the pump if it runs all the time.
Old Jan 19, 2013 | 08:07 AM
jacsent's Avatar
jacsent
ESOF in Auto hub position works now too, but as suspected I will need to find a leak somewhere or faulty pressure switch because it doesn't shut off. Either cannister never gets to pressure or sensor does not shut off pump.
Going to review schematic that Yahiko has.
Thanks all
Old Jan 19, 2013 | 08:45 AM
greentree ford
common place for leak is where the vac lines hook up to the hubs. If you look at back of front tires you will see where the line attaches to the hubs. Unhook one line at at time and plug line with something(a golf tee works really well) and see if you pump shuts off. If so you foun your leak
Old Jan 28, 2013 | 07:36 AM
jacsent's Avatar
jacsent
As it truns out, my pump was faulty and when running, sometimes created a vacuume, and others times not. Turns out the one from my 08 parts truck fit fine. Thanks for the help all.
Old Jan 28, 2013 | 07:55 AM
iron1951's Avatar
iron1951
Glad to hear you chased the problem down. Does that mean your 4x4 ESOF is working too?
Old Jan 28, 2013 | 07:58 AM
jacsent's Avatar
jacsent
Yes sir! ! All is functioning fine
