Not sure if there is one. I searched the forum and came up with a bunch of small threads. So delete this if there is one major thread and make the old one a sticky.
This one should be made a sticky if it receives enough information so that people don't have to search all over the section for it.
Rules.
1) Post Before/After Pics, if you have both
2) Amount of advertised lift
3) Make/Model of Kit
4) What you paid for it/installed
I hope this turns out to be a great resource for this section.
I don't have a "before" but here is "after". 2" AutoSpring cost around $80, installed by me
And heres now, with 3" rear block, AirLift bags and Nitto 295/70-18
Is this kinda what you are looking for other than the "before" pic?
2" Autospring leveling kit (front only). I got the advertised 2" of lift out of it. The tires are 295/60/20 (34.45") Nitto Trail Grapplers.
I installed it myself. The leveling kit cost $75 and I paid $50 for a front end alignment.
Before, with 2.5" of rake. (My God this looks aweful)
After, with .5" of rake.
With this leveling kit...won't your headlights be in the trees (or in oncoming traffics faces) if you are towing...or did you just readjust the headlights down further?
I adjusted them down. The directions for adjusting them are in the owners manual.
Adjustment was easy, IIRC a phillips screwdriver? Alignment was pretty close, had it done @ the Ford dealer when I took it back for the complimentary first OC. I think they charged me $80-90, something like that. Tracks well as far as I know, no issues to speak of.
How do you like the Trail Grapplers on the road? I'm deciding between Terra and Trail.
thanks
I like them. They aren't as loud as most mud terrains but they are louder than all terrains. So if road noise is one of your concerns you might be better off with Terras. For me a little noise is worth the agressive look, but it's not for everyone.
Ready lift 1.5" Not sure of the cost, I got it for chrismas.
1" of rake left.
cooper zeon 275/60/20 (32.99 tall/10.83 wide) No rubbing. Lost about 1 mpg all on highway and city.
perhaps you could put the tire size as part of the criteria. That way everyone knows what looks good and operates well with a given tire size and or any issues that they may have with that given tire size.
Just a thought.
That is a good idea. I will edit my post to reflect that idea.
