Instrument cluster ground
Old Jan 17, 2013 | 09:27 AM
bikeymikey's Avatar
bikeymikey
Hello all,
On to my next project, getting my gauges back. None of them work. I checked fuse # 18, it's good. So next step would be to check the ground. Where is it?
Thanks, mike
Old Jan 17, 2013 | 01:07 PM
Phy's Avatar
Phy
The instruments are grounded at 1 of 2 points: on each side of the cab, under the dash, behind the plastic kick panels in front of the doors.
If that's not it, make sure the connectors on the back of the instrument cluster are plugged in fully.
Old Jan 19, 2013 | 09:11 AM
bikeymikey's Avatar
bikeymikey
Thank you phy. I will check those grounds. I was in the process of pulling the instrument panel, but the speedo cable won't let be get it out far enough to see what's going on behind it. Do I disconnect it at the other end to give me some space? Is there another trick?
Old Jan 19, 2013 | 11:50 AM
Phy's Avatar
Phy
Oh, I thought you were working on the '94...
I don't know about the '89...
Old Feb 9, 2013 | 07:56 AM
bikeymikey's Avatar
bikeymikey
Prrt. It was the fuse. When I said I checked fuse 18 it was a visual check. What do they say? Test, don't guess.
Old Feb 9, 2013 | 08:47 AM
Puddy's Avatar
Puddy
That's why I love those fuses that light up once the circuit is interrupted.
greentruck72
Jun 3, 2016 03:00 PM
Firefighter 1406
Mar 28, 2009 05:27 PM
johaner78
Jan 10, 2008 09:21 PM
loneleader
Mar 4, 2006 11:58 AM
