relocating driver side battery to pass side
Old Jan 16, 2013 | 03:50 PM
ROBZ95XJ's Avatar
ROBZ95XJ
94 idi fact. Turbo
Building my own cai with the wix filter, plan on moving the drivers side battery to the pass side so I can put the filter in its place and box it in for a true cai. Anyways what is the drivers side ground cable conected to it seems to just disapeer under the motor is there any good spot on the dpass side to conect it to?
Old Jan 16, 2013 | 04:40 PM
Blind Driver's Avatar
Blind Driver
Originally Posted by ROBZ95XJ
94 idi fact. Turbo
I would put the batteries in the bed
Old Jan 16, 2013 | 04:47 PM
Bob_Smith's Avatar
Bob_Smith
Really you'd be doing alot of work for no gain at all as from that location you'd still just be sucking warm engine bay air in. If you want to do a proper CAI system what you should do is route a line to suck in air from the grill opening like some of the factory setups on these trucks or do the other better option the cowl intake setup. Go here and read this there is a discussion about this on page 2 with a link to testing done on this subject. Good luck man hope this helps.
Old Jan 16, 2013 | 06:28 PM
Otahyoni's Avatar
Otahyoni
Use a cabover intake.....
Old Jan 16, 2013 | 07:10 PM
ROBZ95XJ's Avatar
ROBZ95XJ
thanks but thats not what im looking for, if i remove the drivers side batterey tray then theres a large area that will get fresh cold air from behing the head light and if i route a tube i can direct air from inside the bumper, i can get sheetmetal for free to box in the area easily and keep the hot air from the engine bay out
Old Jan 16, 2013 | 07:33 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
drivers side ground goes to the front of the engine block down near the crank pulley.
stick with your original idea of a big filter and a box closing it in. it will be way better than cowl air.
Old Jan 16, 2013 | 08:58 PM
SnuffthePunkz's Avatar
SnuffthePunkz
Make sure that you reinforce the pass battery mount, or build a new one that is mounted better and to more than just the fender. Dual batteries on one side has been done a thousand times, you do run the risk of putting to much weight on the fender and causing yourself some troubles down the road. Just do it smart and you'll be fine.
HKusp
17
Apr 8, 2014 08:59 AM
afonda
Jul 3, 2009 10:49 PM
DG65
Jan 2, 2008 05:46 AM
ghunt
Nov 15, 2007 09:37 PM
L84dinr
Sep 5, 2006 06:36 PM
