Sponsored by: Real Truck
Noob here...
Old Sep 5, 2006 | 02:33 PM
L84dinr's Avatar
L84dinr
Noob here...
I have driven Ford Trucks with Navistar diesels since 1983. Good combo.
Anyway I have a F450 an '01 model. I want to add on a Baldwin air filter and do away with the battery on the drivers side. Has anybody had any luck operating their Diesel truck with a single battery. I found a marine battery that has the correct CCA and I think would work for me. But wanted to check to see if anyone else has tried this.
The reason for going to one battery would be to allow cool air to get to the air filter without drawing battery fumes into the air intake, and into the engine. Am I being paranoid re: acid fumes, how ever small amount, into the Air intake.
Thanks for reading.
Raymond
2001 7.3 auto F450 CC
2001 7.3 auto F350 CC SRW
Old Sep 5, 2006 | 02:37 PM
DetailerDave's Avatar
DetailerDave
Since the battery fumes are hydrogen, if I remember correctly, they should give you just a wee bit more power, I would think.
But otherwise, I am clueless.
Old Sep 5, 2006 | 03:47 PM
ryaneverk2's Avatar
ryaneverk2
I think you are indeed being paranoid ... nothing to worry about from the battery running a baldwin or wix filter in a DIY Tymar setup. Hundreds, thousands of guys running that setup with no problems, especially in the older body style.
You can take a look at my pics to see how the filter fits leaving the driver side battery in tact.
I'd think that it would be tough to get started running on one battery... up to you though. But honestly, you'd save work/money/risk of one battery not being strong enough to run on, if you just leave the driver side battery and install the filter and be done with it.
Old Sep 5, 2006 | 04:07 PM
gopedoligist's Avatar
gopedoligist
i agree with ryan, save yourself the hassel and leave the battery.
Old Sep 5, 2006 | 06:36 PM
L84dinr's Avatar
L84dinr
Path of least resistance
OK, Thanks for the tips you all. I have always believed the easiest path is the path of least resistance. Plus, staying with the stock batteries is cheaper. Thanks for taking the time to respond.
Raymond
2001 7.3 auto F450 CC Dually
