390 FE mpg
Old Jan 26, 2013 | 05:13 PM
  #61
jerry73's Avatar
jerry73
Originally Posted by norseman
You were asking about the mileage of a 390. I have an all stock 390 in my '76 F-150 and right now, I would probably be lucky to get 8-10 mpg. I bought it from my Father-in-laws estate when he passed away several years ago and at the time it was running pretty well. It only has about 80,000 original miles and I think that I got about 15 mpg when I first got it on a trip up into northern Washington state with steady driving about 60 miles per hour. I wouldn't count on getting that much though.
I have considered getting an O/D transmission and several years ago, I found a link to a company in Canada that made an O/D that would bolt up to an FE block and if I remember correctly, it cost about $2,500 to $3,000. I don't know if they are still making them though.
I do have one question that maybe someone on the list could answer. I currently need to rebuild the 390 and I understand that they are fairly expensive to rebuild and I was wondering if someone has recently rebuilt one and approximately what the rebuild cost?
Also, when I do rebuild it, I am thinking of putting in a mild cam for towing to increase the power a little. Any thoughts would be appreciated.
At the present price of gas, I can't afford to drive it much, but it is my back up truck and if I need to pull a heavy load, it does serve well.
Thanks for any inputs. norseman
I did the same rebuild you want to do(mild hydraulic cam,bored.60 over,new Stock pistons,rings,and rods,new hydraulic lifters,heads completely worked over,crank shaft completelt balanced and polished) and I had to put it together and it cost me $2500 by the time it was all done(shop bill wad $2200+ I had to buy new distributor and a few other things). The shop I had do it was local and did an extremely awesome job and ordered just the right parts for what I will use it for,I definitely got what I paid for
Old Jan 26, 2013 | 05:16 PM
  #62
jerry73's Avatar
jerry73
My only question now would be how much is my (hydraulic) mild cam going to help me? I went hydraulic because I here they help with mpg
alaskan"70"f250
34
Feb 1, 2015 11:17 PM
WyoExplorer
Feb 15, 2010 09:01 PM
spudgunman
Mar 18, 2009 02:45 PM
montana_highboy
Apr 12, 2008 10:52 AM
averagef250
Feb 8, 2004 11:30 PM
