1978 - 1996 Big Bronco
How to center my steering wheel/adjust tie rods
Old 01-16-2013, 09:27 AM
traderssd's Avatar
traderssd
traderssd is offline
Hi Guys,
Regarding my '91 XLT. I have recently installed a new set of tires and also had an alignment done. Unfortunately, my steering wheel is still a tiny bit off-center. Not a lot and probably not enough for most people to worry about but nonetheless, it drives me crazy and I want to get it perfect. I don't want to take it back to the shop because it's a huge hassle.
So, to correct it, as I undertsand it, if my steering wheel is off to the left, to fix it, I need to shorten the drivers side tie rod and lengthen the passengers side tie rod, correct? My question is, in which direction do I turn the tie-rod adjusters to do this. Clockwise or counter-clockwise, or both and which one is which?
Thank you in advance guys for your help.
Stuart D.
Portland, Oregon
Old 01-16-2013, 11:42 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,193 Likes on 942 Posts
You paid good money to have an alignment done, now you want to screw it up by turning the tie-rods? Yes I know it should only take a small amount of turning but alignments are measured in 10ths of degrees these days. Take it back, let them fix their mistake.
Old 01-16-2013, 01:06 PM
Southern Bronco's Avatar
Southern Bronco
Southern Bronco is offline
Exactly what rla has said. I would take it back and has the shop fix it. I have done alignments for 20+ years, and do not mind making a customer happy.
Armyrules2
12-11-2017 09:51 PM
traderssd
29
10-18-2016 03:54 PM
traderssd
01-16-2013 09:44 AM
carprojects
1999 to 2016 Super Duty
02-01-2011 09:30 AM
rsylvstr
04-25-2008 06:17 AM
Quick Reply: How to center my steering wheel/adjust tie rods
