Bouncing Ranger
Old May 27, 2003 | 09:26 PM
David S's Avatar
David S
Bouncing Ranger
OK, I am tired of this. As I drive down the road, when I hit bumps (even small bumps) the back tires swing left and right, sometimes as much as a foot.
It is a '99 Ranger XLT with 235/70/15's
Shocks are probably factory ( bought it in Dec. 2002).
Is it the shocks or sway bars or a combination?
Old May 28, 2003 | 07:09 PM
Ken00's Avatar
Ken00
Bouncing Ranger
Pickups are very light in the back which lets them get that way, I have heard good things about Bilstien shocks.
Old May 30, 2003 | 08:46 PM
crawlfish's Avatar
crawlfish
Bouncing Ranger
I put Bilsteins on my '96 B4000 and it helped, but didn't cure my problem. My truck drives great on smooth roads, and the Bilsteins even improved this some, but hit a bump and I'm all over the road... seems like the suspension fights itself. I think its design since I've always noticed this problem.
Lately though, I've had an obvious noise under the passenger seat that was diagnosed as a bushing gone bad. They said that it would not affect handling or tire wear, but I'm wondering what the arm and bushings purpose is... maybe cross flex that the truck seems prone to... my terminology might not be correct but if someone can shed more light on this I'd like to hear the answer too.
Old May 30, 2003 | 08:58 PM
Bob Ayers's Avatar
Bob Ayers
Bouncing Ranger
I think you are talking about radius arm bushings. If these are
bad, it will create a looseness in the front end.
I have a 1999 2WD std. cab, and the Bilsteins cured the harsh
ride symptoms I had with the OEM shocks....
Old May 30, 2003 | 09:02 PM
crawlfish's Avatar
crawlfish
Bouncing Ranger
Yep that's it. Now about the looseness in the front end. That will help the seeming shift from side to side? How hard is it to replace? Jack all four wheels up can I get to it readily? Shop wants about $350!
bowdog
1997 - 2003 F150
Nov 8, 2009 07:42 PM
Baumer
Dec 21, 2006 05:10 PM
TomF
Jun 4, 2003 11:42 AM
maroff
Aug 15, 2000 09:45 PM
jevonsack
Feb 7, 2000 08:43 AM
