Water Pump???
Old Jan 15, 2013 | 03:45 PM
cps's Avatar
cps
Originally Posted by BillyBob69
I would love to go the Navistar way but I don't have that much time. I need plug-n-play. So I think I will be going with the over the counter number. If it holds up 3yrs I'll be happy. At least it will have a warranty.
As for pulling the old off and the new on... Any odd tools that I will need to make sure I have?
You will need a big *** wrench,2 1/4 " i believe, to hold the clutch fan or they make the tool to hold it. $25 i think.Strap wrench can work also. there is a write-up for this job somewhere on this site. Maybe Guzzles has a write up. Another tip is to use dielectric grease to hold the gasket in its place on the water pump.
Old Jan 15, 2013 | 03:48 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
I had to go to the international dealer here in town to find ELC suitable for the truck. If you have a truck stop nearby, you can find the ELC, if you want to change to that in the truck.
Old Jan 15, 2013 | 05:00 PM
empiretc's Avatar
empiretc
Ford Super Duty Water Pump Replacement Procedure | Superdutypsd.com
and there is this one:
https://www.ford-trucks.com/forums/a...9&d=1239839789
Old Jan 15, 2013 | 06:13 PM
BillyBob69's Avatar
BillyBob69
Thanks for the links! Those are exactly what I needed.
Old Jan 15, 2013 | 06:14 PM
BillyBob69's Avatar
BillyBob69
Not really "nearby" but maybe I can get my wife's car and go to the two that I know are within 50 miles.
Old Jan 15, 2013 | 06:47 PM
Pitcrw6's Avatar
Pitcrw6
I've heard nothing but bad about the water pumps from the parts store so I would stick with OEM unless you want to be doing it again in a year.
Old Jan 15, 2013 | 06:55 PM
Shake-N-Bake's Avatar
Shake-N-Bake
If you are thinking about going with ELC then I'd recommend that you flush out the old coolant before removing the old pump using this procedure
https://www.ford-trucks.com/forums/9...formation.html
Then replace the pump and fill with ELC and distilled water. I buy my ELC at NAPA for about $12-13 per gallon.
Old Jan 15, 2013 | 07:52 PM
empiretc's Avatar
empiretc
No problem man. Just replaced the one in old green a few months ago.
Old Jan 15, 2013 | 08:49 PM
BillyBob69's Avatar
BillyBob69
Soooo.... Flushing included....
I will need 4 of the coolant and 4 of distilled water... Right?
I saw some earlier threads saying like 4.9 of coolant and the rest in distilled water so I am assuming a total of 8 gallons.
Old Jan 15, 2013 | 09:20 PM
DieselCamper01's Avatar
DieselCamper01
If you are switching over to ELC you will need a lot more distilled water to fully flush the system.
Old Jan 15, 2013 | 09:26 PM
Shake-N-Bake
I ended up using about 18 gallons of distilled water. I flushed twice, which took 7 gallons each. Then drain it for a final time, button everything up (hoses, block plugs, t-stat etc) and pour in 4 gallons of ELC concentrate along with about 3 gallons of distilled water. Then start engine, check for leaks and go for a drive to get the engine up to temp. Park and let it cool and use the last gallon of distilled to top off the degas bottle. Total system capacity is a little over 8 gallons.
Old Jan 15, 2013 | 09:35 PM
BillyBob69's Avatar
BillyBob69
WTH!?!?!! None of my local Napa stores carry that type of anti-freeze. UGH!!
What about G05? Precharged SCA. Will that be OK?
Old Jan 15, 2013 | 09:37 PM
  #28
izzybird's Avatar
izzybird
Some "water stores", for lack of a better description, have distilled water in bulk. Just bring a tote of some sort and fill it up, pretty cheap.
Old Jan 15, 2013 | 09:46 PM
  #29
twg1966's Avatar
twg1966
We flushed a truck at STTD with well water twice, then flushed one and a half more with distilled before tightening all the plugs and dropping in ELC. Truck was then driven from South Texas to Florida pulling a camper. Get concentrate if you can find it. Put in four gallons and top off with distilled. We could only find the premix stuff down here, but then again we don't see the cool temps that you do.
Old Jan 15, 2013 | 10:02 PM
  #30
gengine's Avatar
gengine
The fan tool is worth the buy, or rental. I rented one, used it as a pattern to build my own. I've used it on my truck once, but have used it several times. It's worth having when you need it, plus it works on all 7.3 psd's. I recommend replacing both rad. Hoses while your at it, even if you don't think they are bad. I will try to find it, but there is something about the dual alternator upper hoses...
