239ci flathead Fan
Old Oct 14, 2011 | 07:40 AM
john fin's Avatar
john fin
239ci flathead Fan
Is this the correct fan and hub for a 49' F2?
Old Oct 14, 2011 | 08:10 AM
tinman52's Avatar
tinman52
Welder User
It appears to be....the 6 blade fans pull a lot of air. I switched to a 4 blade, less noisy and don't rob quite as much power. Make sure it is not bent or out of balance.....
Old Oct 16, 2011 | 06:50 AM
38 coupe's Avatar
38 coupe
Yes. You should also have a fan shroud. Before installing the fan, oil the bearings and spin the fan to make sure the bearings are still good.
Gertie-The '49 F2
Oct 5, 2015 07:40 PM
Aaron-71
32
Aug 26, 2011 10:30 PM
volfan16
Garage & Workshop
May 17, 2004 10:55 AM
