Vacuum Line Observation - 4WD
Old Jan 14, 2013 | 04:41 PM
svt2205's Avatar
svt2205
Maybe this is just on my truck, but somehow I doubt it. While rotating my tires today, I noticed that the vacuum line for the IWE is rubbing against an additional spot. When I first got my truck, I noticed the line was rubbing against part of the steering knuckle. My fix was to add a small peice of poly tubing over the vacuum line. The point of contact that I noticed today has worn a notch into the tube that is probably half of the tubing wall thickness. Without doing something, it's just a matter of time before the vacuum line will leak and will cause the IWE to engage unexpectantly.
Just passing this along to you guys.
Old Feb 5, 2013 | 05:16 PM
Toto's Avatar
Toto
Thanx SVT...I will take look in the spring..my truck is a few years old and the might help prevent a permanent partial engagement as others have had.
My buddy had to replace whole hub...it was clicking away for a while.
Old Feb 11, 2013 | 07:52 AM
unibody62's Avatar
unibody62
I have had an issue with my trucks 4WD not disengaging at times. It seems to need a full right or left turn to completely disengage. I don't know if this could possibly be part of the problem, but I will look into it. I think I would try to pad the metal part, rather than the vacuum line.
What exactly is an IWE. The Ford engineer used this term when disgussing my issue with the tech.
Old Feb 11, 2013 | 08:21 AM
johnday's Avatar
johnday
Good catch, thanks for the info. Looks like one of those things to do once the ice/snow are gone. Soon, I hope!!
Old Feb 11, 2013 | 08:38 AM
MisterCMK's Avatar
MisterCMK
Are you sure that is a vacuum line? It looks like the wheel speed sensor to me.
Old Feb 11, 2013 | 09:37 AM
Tinstar36's Avatar
Tinstar36
Good info to have thanks
Old Feb 11, 2013 | 09:54 AM
fordman19762003's Avatar
fordman19762003
that's what I was thinking. I believe the vacuum line is the double line above and behind the one highlighted. I'll have to look at my wifes truck closer tonight.
Old Feb 11, 2013 | 04:12 PM
04XLTRUNNER's Avatar
04XLTRUNNER
the vacuum line is the double line. It goes down next to the axle. The one on top is the wheel speed sensor. It should still be protected though.
Old Feb 13, 2013 | 12:50 PM
svt2205's Avatar
svt2205
I thought it was the vacuum line, but it sounds like I was incorrect. Thanks for steering me straight!!!
johnfist
Nov 3, 2018 01:46 PM
tofino
Oct 12, 2014 04:19 PM
KD4PWH
1997 - 2003 F150
Jan 1, 2014 05:20 PM
FordFanboy
May 17, 2013 03:19 PM
sysco
1983 - 2012 Ranger & B-Series
Dec 14, 2003 06:37 PM
