1991 f250-350 frames similer?
Old Jan 14, 2013 | 04:10 PM
Ryan Weaver's Avatar
Ryan Weaver
Ok i have got a BOSS 8ft V-Plow old electric drive pump fender mounted to a 1991 f250 5.8 4x4. I want to switch this to the 7.3 diesel f350. Frames different? Would they bolt up? 7.3 has a western snowplow with the cable joystick setup.
Old Jan 14, 2013 | 04:29 PM
fdude64's Avatar
fdude64
should be the same
Old Jan 14, 2013 | 07:24 PM
444dieselrod's Avatar
444dieselrod
Frames are the same. If I understand you right you have 2 trucks and you want to put the Boss V plow on the F350 diesel?
Diesel Rod
Old Jan 14, 2013 | 07:34 PM
Ryan Weaver
yup that's right. I have GAS NOW! both have full tanks of gasss!! basically i have two GASSER 5.8's 4x4. 1991's. and one DIESEL 1991! someone says the radiator would be in the way on the diesel f350? not sure. BOSS personal say the plow is absolute and you can;t get parts for it anymore. 1991 F350 won,t handle the weight... They say that it won;t fit on the diesel? unless they don't know what they are talking about? Then i would take off the western and place it on the other GASSER that has NO plow on it. The truck that has the v plow now is rusted out to the max Cab floor rockers bed all rusted through. would you have to drill holes for the western to fit on the (other) f250 without a plow and the stock bumper mounting.
Old Jan 14, 2013 | 08:12 PM
444dieselrod
Hard to say on the radiator being in the way, they do hang down below the frame a few inches. You might have problems with that. Have to pull the brackets off and try, or atleast measure it up.
Diesel Rod
Old Jan 14, 2013 | 09:06 PM
Diesel_Brad's Avatar
Diesel_Brad
Frames are identical. I find it COMPLETELY ASININE on Boss's part to make 2 different plow frames just one for gas, one for diesel. Just make one to fit the diesel and it will fit the gas by default
Old Jan 14, 2013 | 09:45 PM
coxodoina's Avatar
coxodoina
Old Jan 14, 2013 | 11:07 PM
firerescue9's Avatar
firerescue9
just out of curiousity, how much different is there between a 150 and 2/350 frame?
Old Jan 15, 2013 | 06:54 AM
tjc transport's Avatar
tjc transport
i ain't rite
quite a bit. the 150 frame is small and the 250/350 diesel frame is humongous.
Ryan Weaver
Dec 17, 2013 06:25 PM
No More Raptor
Oct 22, 2011 08:55 AM
glm362
Sep 7, 2003 08:02 PM
MustangGT221
Jan 3, 2003 06:33 AM
rockfiv0
Oct 7, 2002 09:28 AM
