Hey guys I hate to ask questions that I could find with more searching but I have worked about 80 hours this last week and tonight is family time. I am looking for a few part numbers if anyone knows them off the top of their heads I would be very thank full. These are going on my grandfather’s 96 F250.
Fuel pressure regulator spring. (looking for the stiffer one) The current spring is bent and only showing about 40 lbs of pressure.
Part number for the O rings for the dip stick tube adapter repair. (Trying to save some money and only buy the O rings vs the hole kit) I have CAT RTV which I assume will do just as good as internationals.
If someone has ever tightened that large nut your oil pan is likely bent and nothing you do will seal it. Outside of getting the dipstick adapter repair kit or replacing your pan, which entails pulling the motor.
