Reinforcements
Old Jan 13, 2013 | 08:17 AM
Gicknordon's Avatar
Gicknordon
Reinforcements
How important are the reinforcement pieces on the fender? Like where they bolt to the running boards, and the back of the rear fenders. Im asking because im almost done with rust repair on one rear fender and wondering if it is worth it to reinforce those areas since the reinforcements are what caused the rust that im fixing. Plus it seems to me that the fender is bolted at enough places that it really doesnt need anything extra.
Old Jan 13, 2013 | 10:08 AM
52 Merc's Avatar
52 Merc
Since it took 60 years for the doubled areas to rust out to the point you had to repair them, I wouldn't worry too much about rust. There are also corrosion inhibitors you can use that will retard the degradation even more that Ford never used if you're still concerned.
Whether or not you feel you need to add extra support for thin sheet metal to keep bolts from tearing through your newly repaired fenders is up to you. They do flex and vibrate pretty good there. Personally, I'd be more concerned about that than rust.
Old Jan 13, 2013 | 10:19 AM
Project-55's Avatar
Project-55
I'm with Merc on this one, The reinforcement plates are needed because the frame and body does twist and flex as you drive. All your hard work will crack right back out if you don't put them back in.
When I put doublers in, I lay down some weld through primer before welding them in place, that way there is some protection against rust.
Gary
Old Jan 13, 2013 | 11:47 AM
Gicknordon's Avatar
Gicknordon
Ok you guys convinced me. I'll just get some weld through primer and spray what the epoxy primer won't reach.
andyj ford driver
17
Jan 12, 2011 10:00 PM
78BigBlock09
Mar 31, 2010 06:48 PM
dustmonkey
Jan 3, 2010 07:00 AM
BroncoPhilly
1978 - 1996 Big Bronco
Jan 2, 2009 04:48 PM
tombob
Jun 22, 2003 08:40 AM
