Rust Starting
Old Jan 2, 2010 | 03:34 PM
dustmonkey's Avatar
dustmonkey
Rust Starting
Anybody have any good experience with the application of fender flares to cover up rusty fenders? I'm starting to get some serious rust on the rear fenders of my '94 F-150. There is enough metal to adhere to or otherwise attach with bolt or adhesive - would after market flares make sense? I wanted to send a picture but I'm new and am not allowed that function.
Thanks, Bob
Old Jan 2, 2010 | 03:43 PM
Hitokori's Avatar
Hitokori
ok well u can use flares... but i would strongly advise cutting the rust off if its all the way threw and sanding back a little and put some primer on it.... if its just surface rust sand it then prime it....
the rust to primer works good for surface rust after u sand it..... then put the flares on...
but pics of the flares u want and the rust will be really helpfull
Old Jan 2, 2010 | 04:02 PM
Diesel_Brad's Avatar
Diesel_Brad
I agree w Hickori if you plan on keeping the truck for any length of time. If not the rust will spread beyond the flair in a short time. I have covered rust w flairs on 3 different truck. You just need the wheel well lip that the chrome trim attaches to to screw the flairs to. the other part just rests against the body w a rubber gasket. I would recomend the BUSHWACKER Stree Flair. They only stick out past the body about 1/2"-1". so you can still run stock tires without looking stupid
The first being a 89 ranger.(in 98) i had 3 pencil sized holes. I used thoes holes as a centering point for a 1 1/2" hole saw and drilled out the rust, teated the left over metal then put the flairs on
The second being a 94 bronco(in 2000). I cut out the rust (almost all the metal the flair would cover) then i had 2 dented up front fenders i cut the wheel well arch out of as a patch. I kept my work small so the flair would cover everything. The quarters were then fix (and strong) then covered w the flair.
The 3rd being a 97 F350 (in 04)that i bought to just resell. The flairs barely covered up the blisters so i cut as little as possible, so the flair still had something to sit against.
Now. All 3 of these trucks i have seen on a regular basis since the flairs were installed. Not one of then has rust com out beyond the flair. A little bit of prep work goes along way
Old Jan 2, 2010 | 08:38 PM
rdw516's Avatar
rdw516
If it hasn't rusted through.....wire brush all the rust you can with a POWER tool such as an angle grinder with a brush on it. Then paint the remaining area with naval jelly OR muratic acid OUTSIDE. (fumes) Let this sit for 10-15 minutes and wash it off with hot soap and water. The acid will eat the remaining rust off and leave a clean surface for primer and paint. I did this with the rims on a '51 Farmall Cub tractor and they turned out great! Granted, the metal was a bit thicker but it did not eat into the good metal, just the rust.
Old Jan 3, 2010 | 05:52 AM
metmag52's Avatar
metmag52
Unless I am way off--if you see rust now it is not surface rust--these trucks rust from the inside out--cutting the rusted parts out and doing a good repair is the only way to save it--I wouldn't mess with covering it with flares until I patched all the rot correctly. After the repairs, I suggest spraying a little oil up inside the fenders at each oil change--makes a little mess till it all runs out, but in the long your truck will last a lot longer.
You can buy aftermarket patch panels which fit very well--makes a tough job much easier.
Just my 2 cents !!
Gary
Old Jan 3, 2010 | 07:00 AM
Diesel_Brad
Just my 2 cents !!
Gary
Correct. They rot from the inside out. You see a blister today and 6 months later you have a hole the size if a quarter. have to cut out the rust to stop it
74baja
Nov 30, 2017 12:30 AM
T. Banning
Jul 27, 2014 05:31 PM
fordman19762003
2004 - 2008 F150
Apr 30, 2012 07:23 PM
