codes
Old Jan 12, 2013 | 02:49 PM
Prof2113's Avatar
Prof2113
codes
Hey guys. Go the dreaded check engine light today. ran the scanner and got the codes below. Any thoughts would be greatly appreciated.
Thanks!
P1151 Lack of HO2S21 switches- Sensor indicates lean
P1131 Lack of HO2S11 switches- Sensor indicates lean
Old Jan 12, 2013 | 03:06 PM
timbersteel's Avatar
timbersteel
If the engine is showing both banks lean, could be clogged fuel filter, bad FPR, wiring fault, or simply both O2 sensors are due for replacement. When were they replaced, # of miles since replacement? I have also seen this with contaminated fuel / E85.
Edit: A bad fuel pump has also known to cause this as it cannot keep fuel pressure steady.
Old Jan 12, 2013 | 05:46 PM
Prof2113's Avatar
Prof2113
O2 sensors (3) were replaced less than 5000 miles back(Bosch). Fuel filter less than 10000 . 330,000 miles on the truck.
Guess I will check fuel pressure next.
Thanks for the information!
Old Jan 12, 2013 | 05:48 PM
Prof2113's Avatar
Prof2113
Btw, it's a '96 OBD2 with the 4.9 with all emissions still intact.
Old Jan 12, 2013 | 06:04 PM
timbersteel
I didn't note that a vacuum hose leak could also trip a Lean condition as well as an intake or throttle body leak. Also vacuum canister leak.
Old Jan 12, 2013 | 06:10 PM
Prof2113's Avatar
Prof2113
Thanks! I'll check for a vacuum leak as well.
Old Jan 13, 2013 | 04:40 PM
Prof2113's Avatar
Prof2113
Would a bad temp sensor contribute? My temp gauge is staying way down even when driving on the highway, so I know I need a new one. Maybe I'll replace it while I am checking fuel pressure.
Old Jan 13, 2013 | 04:50 PM
timbersteel
Yes, I could see a bad ECT sensor causing the havoc. I didn't think of that, but with OBDII, I would think it would show up in a stored code.
Old Jan 13, 2013 | 05:30 PM
rla2005's Avatar
rla2005
The Engine Coolant Temperature (ECT) sensor is not the same as the dash gauge sender. Two different parts with two different functions.
Old Jan 13, 2013 | 06:32 PM
timbersteel
Yeah, dash gauge is on a representation of temp. The ECT is part of engine management.
Joseph Garza
1997 - 2003 F150
Sep 11, 2018 12:42 PM
BCHauler
May 13, 2008 12:20 PM
burninfordrubber
Aerostar
Feb 15, 2007 07:12 AM
crystalmcdowall
1997 - 2003 F150
Jul 22, 2004 12:03 PM
SHOpar
1983 - 2012 Ranger & B-Series
Mar 31, 2003 08:59 PM
