My question regards the headlight switch on a 2006 F150. When rotated all the way to the right, turning on headlamps, the indicator on the switch is lit. However, when the switch is rotated one click to turn on the parking lamps, the "P" indicator is not lit. Is this normal, or do I have a burnt out bulb or defective switch?
OK, my bad... now that it's dark, I see that all the indicators are lit, regardless if the lights are on or not, except the "P". Again... do I have a burnt out bulb or defective switch?
If it's anything like my '07, they should all illuminate. If it's like other switches, the bulb may not be serviceable, easier just to replace the whole switch.
