SYNC Voice Gone
Old Jan 10, 2013 | 02:01 PM
CBBeaty's Avatar
CBBeaty
SYNC Voice Gone
Today, when I pressed the "voice" button on the steering wheel in order to ask the computer to dial someone on the phone for me, the "bell/chime" was not audible. Further the voice which "repeats" what you say didn't speak BUT the system was correctly making the steps. It dialed the proper number but I couldn't hear the person. I reset my iphone and shut the truck completely off, opened the door and then restarted the truck. Nav/Radio synced with Iphone but got same results noted above.
Any help would be appreciated
2012 F 250 Lariat 4x4 with ultimate package
Old Jan 10, 2013 | 02:28 PM
jcain's Avatar
jcain
unplug the sync system fuse (then put it back in after a minute) in the passenger kickpanel and re-add your iphone from scratch.
Old Jan 10, 2013 | 02:30 PM
2000silverbullet's Avatar
2000silverbullet
It's probably best, she's annoying and bossy to begin with..
You can adjust the volume of the voice prompts (as well as your in-call volume). You can either do it in settings or when the unit is barking commands (volume up/down on steering wheel).
Old Jan 10, 2013 | 05:23 PM
bridge's Avatar
bridge
Sick 'n Tired
Laryngitis has been going around
I kill me...
Kidding aside, I beleive this is a know issue and as was already mentioned, a system reset fixes the problem. Good luck.
Old Jan 10, 2013 | 06:20 PM
FTE Herman's Avatar
FTE Herman
I have found that if you just happen to bu turning the volume down when in 'Sync interaction mode' you won't hear anything the next time you try. Stated differently, there's separate volume setting for audio, Sync, and Phone.
Old Jan 11, 2013 | 02:37 PM
CBBeaty's Avatar
CBBeaty
BINGO - Voice is now back
Old Jan 11, 2013 | 04:41 PM
2000silverbullet
Glad it worked, thanks for reporting back!
Truckpilot1329
2009 - 2014 F150
Dec 6, 2017 11:06 PM
82_F100_300Six
Aug 1, 2017 08:02 AM
Adobe 11SD
6.7L Power Stroke Diesel
16
Oct 4, 2014 07:13 AM
Mezmo
2004 - 2008 F150
Aug 3, 2004 09:37 AM
