6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
H&S settings
Old Jan 9, 2013 | 09:08 PM
dieselsmoker's Avatar
dieselsmoker
H&S settings
hey guys im getting an h&s mini maxx and was wondering wat settings i should set my defuels at and wat tranny tune i should run, i use my truck as a daily driver and tow with it. if u could help out would be great
Old Jan 9, 2013 | 10:04 PM
RM2738's Avatar
RM2738
I can't tell you what YOU SHOULD run, but I'll tell you what I run:
Defuel:
Boost: 32
EGT 1: 1350
Low Coolant: 140
Hot coolant: 220
Old Jan 10, 2013 | 12:09 AM
dieselsmoker
what about tranny schedule wat one do u run
Old Jan 10, 2013 | 12:11 AM
RM2738's Avatar
RM2738
Schedule 1 Medium
Old Jan 10, 2013 | 12:19 AM
dieselsmoker
also what pyro do u use for monitoring the egt pyro 1 or pyro 2, thanks for the help i appriciate it
Old Jan 10, 2013 | 05:57 AM
RM2738's Avatar
RM2738
Factory pyros already installed the the truck.
Old Jan 10, 2013 | 06:47 AM
dieselsmoker
ya i know there is 2 of them i seen on the install sheet h&s shows u can pick two diffrent egt sensors to read the egts, i was just wondering if it is the pyro 1 or the pyro 2 to read the egt's befors the turbo's
Old Jan 10, 2013 | 06:49 AM
RM2738's Avatar
RM2738
I only use pyro 1... I think Pyro 2 on the unit is if you get the optional pyro sensor and install it.
Old Jan 10, 2013 | 02:12 PM
GHeTTo JOe's Avatar
GHeTTo JOe
be carefull on like the boost defuel, it will go over that setting. found that out when i had it set at around 36psi defuel and i was pushing low 40's psi. also alot of guys say when towing select the no power setting on whichever tune your running and select the tow/haul and that will run the stock trans settings which is best, BUT dont run the tow haul in the higher power settings. my question is which trans setting is best if you do not want to run the tow/ haul?. also with tow/haul selected will it allow the trans to go into overdrive?
Old Jan 11, 2013 | 09:14 PM
fordtruggy's Avatar
fordtruggy
S1 is best for towing and yes the OD is used in tow haul mode.
Old Feb 4, 2013 | 05:51 PM
countryboy73703's Avatar
countryboy73703
been doing some reading... just want to make sure... I don't need a pyrometer to monitor EGT's correct? to my understanding the 6.4's have them built in and the mini maxx is able to read them... this is correct, right? also.. whats the big price differences about? I see the tuner for around 900, and then on a different site I see the same tuner, just the tuner by it's self for 1500?? whats the deal with that? whats the difference?
Old Feb 4, 2013 | 08:09 PM
finaddict's Avatar
finaddict
I suspect that the difference is how quickly vendors update their prices, or those who still have stock are prepared to sell it at the original price and not jacked up due to no more supply and an increase in demand.
ginomachino
Aug 18, 2016 09:13 AM
satcom40
Aug 14, 2014 01:43 PM
DieselE
27
Nov 28, 2012 07:28 PM
hasteranger
Apr 16, 2012 02:27 PM
hotrod351
May 29, 2010 08:45 AM
