Is 5-7.5 Psi our stock lift pump specs? If so what would happen if i got a 6-10 Psi pump? Im turned up 2 flats but idk if that is enough to make a fuel system pressure fluctuate
Is $120 a good price? Were did everyone else buy theres? And im interested in upping the fuel pressure. I mean with the fuel turned up i don't see why the fuel pump can't be..
it is.they last forever.
but there's no need to pay that much (just send him a pm.he hasnt made a thread in the marketplace or id link to that.)check this out; https://www.ford-trucks.com/forums/1...l#post10774080
and remember,adding fuel is the very last step in adding performance to an engine.you have to work on mods that support being able to handle more boost and fuel before trying to just add fuel.otherwise you'll just have a sluggish and smelly truck.
and how does it perform turned up that far - unless you have a turbo on there, you don't have enough air to use the extra fuel, and will be wasting fuel in the form of black smoke coming out the pipe.
I have a turbo and I have pretty much no smoke at all, I can't wait to get my pyro so I up the fuel. I am thinking it wasn't turned up when the turbo was installed.
