Sponsored by: Real Truck
5.4 falls flat on it's face
Old Jan 9, 2013 | 03:25 PM
mgd4me's Avatar
mgd4me
when this first started the truck would move out the drive way(fuel pump) the only thin that did was make my gauge work again. i then found 2 bad plugs and cop's. no better. i then changed the maf and o2s, both junkyard parts. a little better, the truck will now tach out at 2g rpm's. i then changed the temp and cam sensor. it will now tach out, but after a 10 mile ride it falls flat on it's face. i let it sit for 10 to 20 min and it will run for another 10 miles then fall.i also found that the intake bolts were loose. i can't find any vac leaks ,but it sounds like one near the tb. i can also hear a valve noise in cylinder 7 or 8. i am changing the intake gaskets,and pulling the valve cover to inspect the valves, and new plugs. any other ideas what else to look at? i had code 1130 cleared code after changing maf ,still no code. and when this all started i noticed the tach bounce a few hundred rpm's when i lift off the gas (fuel pump) i think fixed that. this is driving me nuts
Old Jan 9, 2013 | 04:03 PM
Bigpipes 35's Avatar
Bigpipes 35
Originally Posted by mgd4me
I'm having the same problem. when mine first started the truck would move out the drive way(fuel pump) the only thin that did was make my gauge work again. i then found 2 bad plugs and cop's. no better. i then changed the maf and o2s, both junkyard parts. a little better, the truck will now tach out at 2g rpm's. i then changed the temp and cam sensor. it will now tach out, but after a 10 mile ride it falls flat on it's face. i let it sit for 10 to 20 min and it will run for another 10 miles then fall.i also found that the intake bolts were loose. i can't find any vac leaks ,but it sounds like one near the tb. i can also hear a valve noise in cylinder 7 or 8. i am changing the intake gaskets,and pulling the valve cover to inspect the valves, and new plugs. any other ideas what else to look at? i had code 1130 cleared code after changing maf ,still no code. and when this all started i noticed the tach bounce a few hundred rpm's when i lift off the gas (fuel pump) i think fixed that. this is driving me nuts
More info on the truck please.
Old Jan 9, 2013 | 04:11 PM
mgd4me's Avatar
mgd4me
'99 5.4 at sc, lb, srw, with a clean cat and 4:10 gears. trans,oil ps coolers. with esof elimination
i was getting a lean code on bank 2. that is one way i found the bad plug and cop. i replaced those 2 cops and plugs...no more miss.
Old Jan 9, 2013 | 04:24 PM
redford's Avatar
redford
FTE Leadership Emeritus
Have you checked your catalytic converter for a possible exhaust obstruction?
Old Jan 9, 2013 | 04:26 PM
mgd4me's Avatar
mgd4me
cat is cleaned out, first thing i thought of..then i remembered when i replaced the engine i cleaned the cat out. this truck ran great for about a year. then it started all at once.
Old Jan 9, 2013 | 06:08 PM
bionicseahorse's Avatar
bionicseahorse
how is the idle?
Old Jan 9, 2013 | 06:11 PM
bionicseahorse
if you had a faulty plug or cop then there's a chance you could melt your cats. its never happened to me in my truck just a car that I had. Same symptoms.
Old Jan 9, 2013 | 06:12 PM
bionicseahorse
drop your exhaust just to check its free and takes about 20 minutes.
Old Jan 9, 2013 | 06:39 PM
Bigpipes 35
[quote=bionicseahorse;12694808]drop your exhaust just to check its free and takes about 20 minutes.[/quot
His cat has been gutted
Old Jan 9, 2013 | 07:46 PM
mgd4me's Avatar
mgd4me
Originally Posted by bionicseahorse
how is the idle?
the damn thing will
idle all day just fine, but won't tech out past 3500 RPMs when warm unless you shut it down then it will tech out full red line
Old Jan 10, 2013 | 10:12 AM
bionicseahorse
Geez idk man this is a shot in the dark but blown head gasket..... just a shot u know a guess. Thoses are crazy symptoms
Old Jan 10, 2013 | 10:16 AM
mgd4me's Avatar
mgd4me
i can "almost" rule out a hg. no oil in the water or water in oil and not using water. other than normal, but one never knows...
Old Jan 10, 2013 | 10:21 AM
bionicseahorse
have you checked compression?
Old Jan 10, 2013 | 11:07 AM
mgd4me's Avatar
mgd4me
if it was compression , why will it idle all day with no problem. it only acts up after driving about 10 miles, or after it warms up.it will run like a raped ape when cold...and fuel pressure is at 30 psi @idle and up to 45 psi @ 3g rpms..
Old Jan 10, 2013 | 04:36 PM
redford's Avatar
redford
One engine I had also had a problem...would get to a certain RPM then refuse to go any faster. That issue was the timing chain was about to expire, it had stretched so much it allowed the camshaft (just one on that engine) to slip a few teeth.
