Sponsored by: Real Truck
5.4 falls flat on it's face
Old Jan 10, 2013 | 05:06 PM
mgd4me's Avatar
mgd4me
Originally Posted by redford
One engine I had also had a problem...would get to a certain RPM then refuse to go any faster. That issue was the timing chain was about to expire, it had stretched so much it allowed the camshaft (just one on that engine) to slip a few teeth.
If that was the case wouldn't it back fire when the chain skiped?i don't have a miss. mine only acts up when warm.
Old Jan 10, 2013 | 05:26 PM
redford's Avatar
redford
FTE Leadership Emeritus
It started normally and did not backfire. I seem to recall it also ran a little better when the engine was cold, but not by much.
Old Jan 10, 2013 | 05:33 PM
mgd4me's Avatar
mgd4me
mine runs great cold, but like $h 1t warm so maybe.I will look at that when I replace the intake gasket...nothing to lose, and a few miles on the engine.I will let you know what I find out this weekend
Old Jan 21, 2013 | 12:50 PM
mgd4me's Avatar
mgd4me
Update: changed the intake gaskets,seems to have worked, but not sure.now I get code p0356.no 5 and 6 not fireing.coils are good,new plugs power on both sides of plug with the truck runing....any ideas???I was told the pcm...
Old Jan 21, 2013 | 01:04 PM
PoCoRedneck's Avatar
PoCoRedneck
Other possible Cause
I was getting a lean bank reading on my 2000 Expedition with a 5.4 It ended up being the intake manifold was leaking. I suppose if the leak was bad enough it could cause acceleration issues. I started losing a lot of water off the back of the engine. Did you put electric grease on all the connections and on the plugs?
Old Jan 21, 2013 | 01:13 PM
mgd4me's Avatar
mgd4me
That's why I changed the gaskets.and no grease yet.I want it to run first b4 I really do that.and it's not a moisture issue.and yes I was losing water.it was all on the top of my block, along with a mouse nest
mgd4me's Avatar
mgd4me
Could it be the connectors on the coils??
Old Jan 23, 2013 | 10:05 AM
mgd4me's Avatar
mgd4me
help need to get this damn truck out of my buddys yard
Old Feb 3, 2013 | 03:12 PM
mgd4me's Avatar
mgd4me
Fixed... Broken wire in the harness factory splice for cops 5 snd 6. pita...it was... All new gaskets and no more vacume leaks
Idaho Hillbilly
2004 - 2008 F150
Feb 22, 2019 07:45 PM
FordMan9707
Jan 29, 2015 09:03 PM
spb_8980
Modular V8 (4.6L, 5.4L)
Jan 14, 2013 03:44 PM
mattnj
Jun 15, 2010 03:58 PM
fordguy4life
1997 - 2003 F150
May 11, 2006 07:14 AM
