H&S or SCT Programmer?
Old Jan 8, 2013 | 02:59 PM
TxFord0207's Avatar
TxFord0207
2006 Ford F250 115K
new head gaskets, arp head studs, upgraded FICM, new blue fuel spring, new stc fitting and branch tube, new dummy plugs and standpipes, upgraded oil cooler, Bulletproof EGR cooler, K&N full cold air intake and filter, 4" straight pipe exhaust.
Which programmer should i get?
Please , i would just like some real honest opinions and if any one has either one with a 6.0L, okease let me know.
As always, thanks for the help guys.
Old Jan 8, 2013 | 03:41 PM
tex25025's Avatar
tex25025
Originally Posted by TxFord0207
2006 Ford F250 115K
What is in bold is not really needed. Far better to have stuck with a stock filter. Even at 508HP on my truck, the stock filter is still sufficient for my needs.
As to your two tuner choices. SCT hands down. You can't beat custom tunes. What kills H&S, in my opinion, is that it's shift on the fly. Besides the novelty of that, it's not worth it. Because it isn't properly tuning the vehicle you run into longevity issues (Edge shift on the fly tuners were notorious for wrecking havoc on the tranny, even as stout as the TS is in stock form).
Old Jan 8, 2013 | 04:28 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
We have a couple different options as far as 6.0L's go.
We carry SCT programmers, and our Infinity programmer/monitor.
The SCT devices will just hold/flash tunes.
The Infinity will hold/flash tunes, monitor PID's(generic and Ford specific), run tests(KOEO/KOER, buzz, cyl contribution, etc.), play media, etc...
You can check it all out here... Programmers - Tuning - 2003.5 - 2007 Powerstroke 6.0 Truck - Ford Powerstroke
Let me know if you are interested in either. I will be glad to help you out.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Jan 8, 2013 | 04:40 PM
tex25025's Avatar
tex25025
The LiveWire and the TSX will monitor PIDs and scan for codes as well as tune.
Old Jan 8, 2013 | 05:16 PM
TxFord0207's Avatar
TxFord0207
Tex25025 - well the K&N and the exhaust was on the truck when i bought it so i have just left them. It was not something that i added myself.
Thanks for the info too man.
Justin- i liked this one.
iTSX / TSX Wireless Vehicle Programmer
tell me about it?
Tex- is this the one you were talking about?
Old Jan 8, 2013 | 05:22 PM
Regulator1988's Avatar
Regulator1988
sct is way batter
Old Jan 8, 2013 | 05:23 PM
TxFord0207's Avatar
TxFord0207
Tex and Justin -
i also like this one, i like the idea of having the touch screen monitor.
Livewire TS Performance Programmer & Monitor
Old Jan 8, 2013 | 05:40 PM
tex25025's Avatar
tex25025
My experience with the SCT is limited to the xCal 2 and X3. The old version of the LiveWire had been plagued with issues, mainly a power issue (not vehicle power, but electric power).
TSX I don't recall anything bad about it. The only thing that I would be concerned with is the Wireless connection. Now it could just be my own mental thing, I don't know, but call me an "old fart", but there is nothing like a good hardline connection in my mind. Funny thing though, is that I'm usually pretty techie, but for some reason I haven't embraced wireless tuning.
Old Jan 8, 2013 | 05:47 PM
rhjj's Avatar
rhjj
Have had a SCT from Innovative Diesel for over 100,000 miles. No transmission or engine problems. H&S no personal experience.
Old Jan 8, 2013 | 06:19 PM
Justin@DP-Tuner
PREMIUM SPONSOR
That is correct. I didn't even mention the code reading feature because pretty much every unit that plugs into the OBDII port will do that.
tell me about it?
The SCT iTSX is a wireless tuner/data monitor. It works via Bluetooth to connect to your Apple device. It will hold up to 12 custom tunes.
You can check it out, along with its features, here... SCT-iTSX-4015 6.0L - Programmers - Tuning - 2003.5 - 2007 Powerstroke 6.0 Truck - Ford Powerstroke
Tex and Justin -
The SCT Livewire TS is also a tuner/data monitor. It is a 4" touch screen device. The TS can hold up to 10 custom tunes.
You can check it out, along with its features, here... Livewire TS 5015 6.0L - Programmers - Tuning - 2003.5 - 2007 Powerstroke 6.0 Truck - Ford Powerstroke
__________________
Justin
www.dp-tuner.com
Old Jan 8, 2013 | 06:51 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
SCT and custom tunes from several sources Like Gearhead and Quicktricks.
Then use DashBoss, SG2 or Torque for PID monitoring.
Josh
Old Jan 8, 2013 | 06:53 PM
tex25025's Avatar
tex25025
True, however, they aren't all created equal when it comes to getting those codes either. The xCal 2 that I had did a far better job then the X3 (there was a time that I had both in my possession, so I would test to see if they would both pick up codes, didn't always match).
If I recall correctly, a lot of the old Diablo users kept there tuners just for the code reading ability.
Old Jan 8, 2013 | 07:29 PM
Justin@DP-Tuner
PREMIUM SPONSOR
I agree. I have a few different scanners including my Infinity. The Infinity will pick stuff up that even my Snap On Solus won't.
__________________
Justin
www.dp-tuner.com
Old Jan 8, 2013 | 08:51 PM
TxFord0207's Avatar
TxFord0207
Any opinions on this one ???????
EDGE
Ford Juice with Attitude CTS - 2003-2007 Ford Powerstroke 6.0L Juice with Attitude CTS
Old Jan 8, 2013 | 09:00 PM
tex25025's Avatar
tex25025
EDGE
Shift on the fly. Not good.
I do not think their Evolution product is shift on the fly. However, with canned off the shelf tuning, your truck may or may not "like" the tuning. Some trucks respond really well to one size fits all tuning, some do not. Some may respond really well to the lower power levels, but don't like the higher ones (I guess vice versa is possible, but I never heard it mentioned).
If you really aren't fond of the SCT then I would try to find something that would handle custom tuning.
I do believe Power Hungry makes a tuner and uses the Edge monitor (CS and CTS (which I do believe is the monitor that you have posted) monitors) as a base. I think it's called Gryphon.
