Bad Carburetor?
Old Jan 8, 2013 | 01:54 PM
fixorrepairdaily100's Avatar
fixorrepairdaily100
Bad Carburetor?
Ok, So I swapped a 390 for a 360 after I broke a rod. The carburetor from the 390 was working, but I put it on the 360 and now it wont run. The jets squirt fuel, but I dont know if its getting to the cylinders. When I spray carb cleaner in the carb, it will run for a few seconds, but then shut off. Is this a carburetor issue or am I missing something?
Old Jan 8, 2013 | 04:47 PM
f5fordgirl's Avatar
f5fordgirl
Have you checked for vacum leaks in the gaskets under the carb, did you hook the pcv hose and power brake booster hose back up?
Old Jan 8, 2013 | 06:08 PM
fixorrepairdaily100
I did not know those were necessary to make it start, i hooked them up using the old adapter because it fits better on the hose, thank you, i got it to run, now i just need to do the fine tuning before i hit the mud
65f100pdx
16
Jun 17, 2020 11:34 AM
59CRL
Jul 17, 2011 02:52 PM
mlf72f250
Mar 22, 2004 02:35 PM
Seifferlein
Nov 2, 2002 12:48 PM
dbarracuda
Oct 14, 2002 07:51 PM
