Rough Running 05
Old Dec 13, 2012 | 07:22 PM
viper29's Avatar
viper29
Rough Running 05
I have a 2005 F250 automatic, 6.0, with 139,000 miles on it. Done some upgrades this spring to the engine.
Replaced the oil cooler, EGR cooler,STC fitting, oil tubes for the turbo, water filtration system. Ran fine until about month and a half ago starts great. If I don't let the engine get to operating temp it spits and sputters and (jerks once in a while), when you pull out and give it fuel. But when you give more fuel it will smooth out for the most part. Even at 65 if you just crack the fuel you can still fill a little roughness. Changed fuel filters, fuel, seafoam, water remover, and one have any suggestions? No codes, no check engine lights.
Old Dec 13, 2012 | 08:41 PM
RideDiesel88's Avatar
RideDiesel88
Injectors? FICM voltage? Check Odometer trick, youll probly find a code. Clean EGR? Does it feel like the tranny? more info
Old Dec 13, 2012 | 09:00 PM
BLADE35's Avatar
BLADE35
A Gauge setup will pay for itself here
I use a ScanGaugeII
there are other gauges that work great to but better post what one your getting as some gauges wont do what you need it to
Check FICM--Batterys--Alternator to start with
Old Dec 14, 2012 | 08:43 PM
viper29's Avatar
viper29
No I don't think it's the tranny. But I will check the FICM, batteries, starter, alternator tomorrow. Thanks
Old Dec 15, 2012 | 04:35 PM
2006powerstroke90's Avatar
2006powerstroke90
Pretty sure the key trick does not work on these fords.
Scan gauge II will be your best friend.
Old Dec 15, 2012 | 05:50 PM
mustang_309's Avatar
mustang_309
What oil are you running in the ole girl? I switched from 15W-40 to rotella T-6 5W-40 and it smoothed her right out.
Old Dec 15, 2012 | 05:55 PM
BLADE35's Avatar
BLADE35
Well if its a Female Truck theres the Problem LOL
she will smooth out in 7 days or so
Old Dec 15, 2012 | 09:04 PM
mustang_309
LOL you got me on that one
Old Dec 16, 2012 | 06:04 PM
viper29's Avatar
viper29
I've used Rotella 15W-40 every since I got the truck. Not knowing what the previous 2 owners used.
Old Jan 7, 2013 | 08:26 PM
viper29's Avatar
viper29
Finally got it scanned, #3 injector is going bad. Nothing else showed up.
JPSLLC
Jul 24, 2015 08:10 AM
skyline82
Dec 10, 2013 11:09 AM
scameron
Jan 28, 2012 11:56 PM
_Me2_
Dec 1, 2010 10:56 PM
450Ford4x4
Nov 16, 2008 07:46 PM
